Old 09-09-2017, 05:57 PM   #1
70K10Hunter
70K10Hunter's Avatar
Rams horn manifolds
I thought I saw one time a set of Rams horn manifolds that would accept an A/C compressor, but I believe they were for the 67/72 models. Would they work for a 73/80 with an A6 compressor?
Does anybody know where I could acquire a set?
if in fact they do.
70K10Hunter is offline   Reply With Quote
Old 09-11-2017, 01:34 PM   #2
andyh1956
Re: Rams horn manifolds
I bought a new set of 2 1/2" Chicom Rams Horns at Pate this yr & they both have the bracket on them to mount something, A/C comp or wind mill I don't know...
andyh1956 is offline   Reply With Quote
Old 09-11-2017, 03:13 PM   #3
Malo83
Cruzzzn' Vet
Malo83's Avatar
How about these?
http://www.speedwaymotors.com/Corvet...fold,9133.html
Malo83 is offline   Reply With Quote
Old 09-11-2017, 04:06 PM   #4
MikeB
MikeB's Avatar
The bracket on the 2.5" models is for a mid-1960s generator.
For a pickup you really need the ram's horns with angled outlets to clear the crossmember. However, I don't know if they would clear your compressor, since they rise up much higher than the 73-87 "log type".
Dorman 674201, left side (Right side is 674199)
Mike
1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress.
1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 09-11-2017, 08:02 PM   #5
70K10Hunter
thanks guys. Upon further investigation I noticed that my A/C comp has a rear support mount which bolts between the 2nd and 3rd bolt hole and the Rams horn ain't gonna make it. So I guess its the log style or maybe some headers and make spacers for the rear support.
Gotta have my A/C it is Texas you know.
Old 09-11-2017, 10:12 PM   #6
72freak
Rottenwood Garage Member
72freak's Avatar
This is a common misconception. Straight dump 2.5 ram horns clear fine. I put them on every 67-72 I built over the past 20 years. 2x4, 4x4. Now with that said, the kick backs do allow for less of a bend at the start of the exhaust pipe and i will certainly give them a try on one of my next builds!.
2004 Chevrolet Suburban C1500
2001 Chevrolet 2500HD Crew 6.0
1999 Harley Davidson Electra Glide
1972 Chevrolet C-20 Custom Camper "Dump Truck"
1972 Chevrolet C-20 Suburban "Big Green"
1969 Chevrolet C-50 Wedge Hauler "Leonidis"
1966 C-10 2x4 short fleet 327 4 speed "Race Truck"
1952 Plymouth Cranbrook "Rican" (my grandfathers)
1931 Ford Model A Coupe "Black Beauty"
1930 Ford Model A truck "Club Cab" 4x4
Rottenwood Garage and Speed Shop.....where everything must be racy!
It's not just a hobby..It's a LIFESTYLE!!!
Thanks for nothing Barrett-Jackson
You cant fix stupid or teach accountability!
Time wasters, looky Lous and tire kickers are everywhere!
72freak is offline   Reply With Quote
Old 09-11-2017, 11:37 PM   #7
MikeB
MikeB's Avatar
Interesting. I had a pair of the 2.5" Dormans that would have required a very tight radius bend on my old 69 C10. I am partial to large mandrel bends, and doubt one could be made that tight. The larger the radius the better! However, those manifolds would have worked on a K10, because the engine was mounted farther back.
On my 82 C10, I might have been able to make them fit had I notched the motor mount clam shells, but would have had the same issue with the tight bends.
If the OP needs manifolds, I have these sitting on the shelf. They're for a 96-up 350. I used them on my 82 C10 for a year or so before I switched to headers. What I like about them is they don't have air injection ports. The stub pipes and flanges are 2-1/4".
Mike
Old 09-19-2017, 08:17 PM   #8
GMDad
GMDad's Avatar
Were you able to use the stock pipes from an 82 with these manifolds? I am going to replace the 305 I my 86 and want to remove injection pump etc and those manifolds looked really good on yours.
GMDad is offline   Reply With Quote
Old 09-19-2017, 08:50 PM   #9
MikeB
MikeB's Avatar
No, I modified the head pipes in a 73-87 Heartthrob Exhaust kit using extra pipes and mandrel bends that were included for long wheelbase trucks. But any muffler shop can make the connections.
96-up trucks use a Y pipe with CATs and probably wouldn't fit an 73-87 anyway.
Mike
Old 09-21-2017, 09:43 PM   #10
54Caddy
GM Addicted
54Caddy's Avatar
N2trux has a set of 2.5 ram horns on his truck
..Mac’s Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is offline   Reply With Quote
Old 09-22-2017, 06:05 AM   #11
mcmlxix
Collector of Projects
mcmlxix's Avatar
I have a factory 2wd 78 Blazer and asked a friend to swap some 2.5" ram horn manifolds from the old headers. I was in the process of moving so it would have been a perfect time. He came back a week later and said they wouldn't fit.... They were Speedway Motors smoothie that dump straight down...
Rich
1972 K5 Blazer CST Click HERE
Old 09-22-2017, 09:39 AM   #12
MikeB
MikeB's Avatar
54Caddy -- That is a very nice installation, at least on the passenger side. Do you know if he had to notch the driver side clam shell to clear the manifold flange?
And I wonder what the driver's side head pipe bend looks like. On my 82 C10, it would have been a severe bend starting right at the flange to clear the crossmember.
Mike
Old 09-24-2017, 05:10 AM   #13
54Caddy
GM Addicted
54Caddy's Avatar
No he says in thread that he didn’t have to notch motor mounts. Passenger side he did change to a mini starter since OEM style was bad so I’m sure that helped with clearance a bit. Drivers side I’m sure has a crazy bend to it but that’s all just in finding an exhaust shop that knows what they’re doing.
..Mac’s Garage..
IG:MacsGarage
Old 09-25-2017, 02:11 PM   #14
kacy
kacy's Avatar
anyone have these on their stock height 4x4s?
79 Corvette- 406/7004r Holley EFI
87 V10- 5.7L, Vortec heads, E110026, 410s 35s, 700r4
kacy is offline   Reply With Quote
Old 09-27-2017, 12:51 AM   #15
N2TRUX
Happy to be here
N2TRUX's Avatar
Roger Lynsky of RPL built a custom Y pipe and we ran a single 2.5" pipe back to a large mouth CAT followed by a SI/SO Flowmaster with a tailpipe that ran to the rear of the truck. There were no clearance issues, and no crazy bends in the pipe. The sound was nice a smooth till you nailed it and then it talked nasty.
Later when we installed the 4 link, I had to cut the system shorter to clear. Now its just loud, and doesnt sound as clean. I plan to make changes to that soon.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 09-27-2017, 01:37 AM   #16
mcmlxix
mcmlxix's Avatar
So I have a 78 factory 2WD with a SBC. I used a late model factory mini starter. I have a serpentine belt setup so I should be OK with the ram horn manifolds?
Would you recommend studs for the manifolds? Have a part number? I would guess Dorman should make some...
Rich
