Old 09-09-2017, 06:54 PM   #1
Fire24
Front drum anchor bolt
I need the front drum anchor bolt that holds cylinder and springs. Any place to buy one? 1968 chevy c10
Fire24 is offline   Reply With Quote
Old 09-09-2017, 07:28 PM   #2
berch 69GMC
berch 69GMC's Avatar
Re: Front drum anchor bolt
How did you remove it? My driver side will not budge, heat pb blaster, impact,and breaker bar failed for me
berch 69GMC is offline   Reply With Quote
Old 09-09-2017, 07:49 PM   #3
AussieinNC
Moderator
AussieinNC's Avatar
I'm converting my drums to disc, starting tomorrow...
You can have one of the ones currently on my truck...67 C 10...so long as I can get it out.
I will pm you tomorrow after I get it out...
AussieinNC is offline   Reply With Quote
Old 09-09-2017, 08:09 PM   #4
Fire24
Mine was driver side too. Man I had to cut the nipple off so could get a better grip. That didn't work so I had to cut the brake cylinder off and then cut the piece that was behind brake cylinder. It came out easy after that.
Old 09-09-2017, 08:10 PM   #5
Fire24
Thanks I would appreciate it very much. I will buy it from you.
Old 09-10-2017, 11:50 AM   #6
AussieinNC
Moderator
AussieinNC's Avatar
Have the anchor pin and lock plate out and cleaned up for you.
Pm me to arrange shipping.
Suggest best to wait until IRMA has passed...as I see you are in FL...
Stay safe mate...
Old 09-10-2017, 12:33 PM   #7
Fire24
Thanks brother I appreciate it. I sent u my address. Let me know what I owe you
Old 09-11-2017, 02:30 PM   #8
custom10nut
custom10nut's Avatar
Carefully heat it with a torch, and melt a little candle wax into it while tapping on it. Then hit it with the impact again. This is an old gear head tech tip that hasn't failed me yet.
custom10nut is offline   Reply With Quote
Old 09-11-2017, 02:40 PM   #9
AussieinNC
Moderator
AussieinNC's Avatar
I have had much success using an 1 1/8" deep impact socket over the bolt, smacking the end of the socket with a 5lb hammer, then using an electric 1/2" impact gun...
If it doesn't come out, I usually try tightening it, then trying the reverse direction...have removed probably 100 this way...
"Fire24"...parts are ready to ship, just waiting on IRMA to finish her run...
Old 09-11-2017, 02:58 PM   #10
weq92f
weq92f's Avatar
Wax eh?
Is the timing of impact important?
-Kevin
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 09-11-2017, 03:01 PM   #11
AussieinNC
Moderator
AussieinNC's Avatar
The smack on the deep socket is to loosen any rust within the threads...
The impact saves many a skinned knuckle...trust me...
Timing of impact...not important...
