Old 09-10-2017, 10:14 AM   #1
lamchop
lookin for sum insight on 4 6 drop
was thinkin on droppin my truck (66 shorty fleet) can get 3 5 or 4 6 drop kit for same price. comes with springs,shocks, shock relocators, adj track bar. pretty much everything except c notch.....(which i hear conflicting stories as to whether its necessary or not)?? is a 4 6 kit too much? will springs /shocks,etc...be all i need? never dropped a truck before. is an alignment neccesary after install? any other concerns i should be aware of? i appreciate any help or guidance. thanks fellers!
lamchop is offline   Reply With Quote
Old 09-10-2017, 12:24 PM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: lookin for sum insight on 4 6 drop
6" drop will need the c-notch in the frame!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 09-10-2017, 04:18 PM   #3
forestb
forestb's Avatar
Some people have problems with 6 inches in the rear and others don't. You might want to do drop spindles in the front and drop coils. You will have to switch to disc brakes up if you do but it will give you better geometry and much better braking. You might want to just do a 4\5 drop using a 4 in drop coil and a 1 in drop block and see how you like it. You could always install a 2 inch block later. By using a 4 in coil and drop blocks it will keep your shocks at a better angle in the rear and that way you might not have to relocate your rear shock mounts. You will have to get your alignment done up front after everything is installed. Also you could install the 4 inch drop coils in the rear and then put something heavy in the bed to see how much lower you want it.
forestb is offline   Reply With Quote
Old 09-10-2017, 05:16 PM   #4
YOLO
Custom Truck Lover!
YOLO's Avatar
I need to notch my rear it's hitting so hard on every little bump.
Squarebody guy
YOLO is offline   Reply With Quote
Old 09-11-2017, 11:49 AM   #5
rvrfoot
I have a 5 7 drop with a c notch. Its hard to see but i have about 1 1/2 before axle is in the frame.Name:  DSCN0911.jpg
rvrfoot is offline   Reply With Quote
Old 09-11-2017, 12:01 PM   #6
lamchop
Im trynna shy away from changing the spindles.....$$... the kit im lookin at is from western chassis. Round $520 shipped. Will dropping the front 4" with springs and shock relocators cause an issue with the steering geometry??....and hope its not a Silly question....but whats difference in using drop springs vs lowering blocks? My brain says yer still dropping (x) amount of inches?? Wouldnt using blocks screw with the spring rate? Jus askin cause i dont know much about suspension stuff.. Thanks again!����
Old 09-11-2017, 12:03 PM   #7
rvrfoot
I have blocks and springs there is a picture of mine.
Old 09-11-2017, 06:02 PM   #8
jchav62
1962 C-10
jchav62's Avatar
I wouldn't recommend going down 4" in front without spindles. If $$ is an issue, go with a 2"-4" drop. Get the lowering coils for the rear, no need for a c-notch with 4". Then for now, if you're on a budget, take a cutoff wheel and cut off about a coil and an half of the front coil... BAM! Budget coolness.
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 09-11-2017, 08:49 PM   #9
rvrfoot
Its less then $100 bucks for a coil.
Old 09-12-2017, 05:30 AM   #10
northern 85
northern 85's Avatar
Size:  55.9 KB 2 1/2 spindle 1 1/2 spring 6 inch spring in the rear no notch yet shock re locators short rubber bump stops
northern 85 is offline   Reply With Quote
Old 09-12-2017, 07:46 AM   #11
The Mule is A 4.5 m (2.5 spindles, 2" drop springs)/ 6 (6" springs and shock re-locator)drop, no c-notch. All my stuff is an ece drop set up. I do have to watch big dips as it will occasionally bottom out, but normally no issues. The cut down bump-stops fell out and I have yet to replace them. I am thinking about adding a c-notch, but normally can't stop driving it to do any work on it.
Old 09-13-2017, 12:20 AM   #12
ezz16
I do not have pics on this computer but my son and I just did a 3in front and 5in rear kit from summit racing. cpp I think it was. $328 free shipping and couldn't be more pleased. put 235/75/15 white walls.
ezz16 is offline   Reply With Quote
Old 09-13-2017, 12:27 AM   #13
ezz16
found a picName:  yes.jpg
Old 09-13-2017, 02:50 AM   #14
La Zona Imagery
Originally Posted by rvrfoot View Post
I have a 5 7 drop with a c notch. Its hard to see but i have about 1 1/2 before axle is in the frame.Attachment 1689277
You were able to drop the rear 7 inches and was able to keep the stock track bar? Does it drive well? I am thinking of doing the same thing.
1965 Chevy C-10 350 V8
2003 GMC Sierra Crew Cab 6.0L 4x4
La Zona Imagery is offline   Reply With Quote
Old 09-13-2017, 11:24 AM   #15
forestb
forestb's Avatar
You will need a new track bar. I needed one with a 4 inch drop. You will definitely need one with a 7.
Old 09-13-2017, 05:50 PM   #16
the_real_dock
Here's mine for reference. 4-5(?)" drop in the front. Not sure really. I think I cut 1.75 coils off. The rear is 8" using 2" blocks and 6" springs.
No notch yet. You can see how close the axle is to the frame. The truck isn't officially on the road yet, but I've had it on some back roads around 30mph or so with no issue. The springs are fairly firm so I *think* I'll be ok. I have no delusions about hauling anything or being able to play Luke Duke, but that's not what this truck is for.
the_real_dock is offline   Reply With Quote
Old 09-14-2017, 12:07 AM   #17
rvrfoot
I do still have my stock track bar. I will try to find some pictures of it.
Old 09-14-2017, 12:40 AM   #18
La Zona Imagery
Ok thanks. I was thinking about droping my rear 6 inches (4 inch springs, 2 inch blocks) or 7 inches but didn't know if a new track bar was really needed.
Old 09-14-2017, 12:42 AM   #19
La Zona Imagery
I have a 4 inch rear spring drop right now w/ the stock track bar. Maybe shortbeds are different from longbeds? I dunno
Old 09-14-2017, 07:23 AM   #20
zach_carver
zach_carver's Avatar
4" Front drop springs are a bad idea IMO. My 3" drop springs will come loose when I jack my truck up. They arent tall enough to stay in spring pockets correctly. Yes an alignment is required after lowering one any.
1965 C10 LS2/4l70, WHITE, 5/7 DROP
LINK TO SUPER SNOOPY C10 BUILD---> http://67-72chevytrucks.com/vboard/s...d.php?t=689283
1977 C10 SILVERADO HAWAIIAN BLUE, 5/5" DROP, LS6/4L80E
1976 CHEVY K5, 350/350, YUBA GOLD/SADDLE
zach_carver is offline   Reply With Quote
Old 09-14-2017, 11:30 AM   #21
forestb
forestb's Avatar
And your rear wheels have not been pushed to one side? Have you measured between the backs of the drums and the frame rails to see if your axle is still centered?
Old 09-14-2017, 11:49 AM   #22
La Zona Imagery
No the rear wheels haven't been pushed to the side. Yeah the axle is still centered. I will post a pic when I get home later today.
Old 09-14-2017, 03:42 PM   #23
rvrfoot
Look at my picture and Post Number 5 7 inch drop still got the stock bar
Old 09-14-2017, 08:25 PM   #24
Clyde65
Clyde65's Avatar
Are yall's stock bar bent?
Clyde65
Rebuild of Clyde
support our troops!
Old 09-14-2017, 10:45 PM   #25
rvrfoot
Nope
