Old 09-11-2017, 10:17 AM   #1
Mattchu60
Need a slip yoke for K20 - anyone know the right one to order?
I am having a new driveshaft made for my pickup - long story short - this truck was originally a k10 with a 700r4/np208. I have swapped the 14 bolt into the rear using my original driveshaft and a "trick" u-joint to make it work.
My drive shaft is slightly bent so having a new one made - I want to have one made to "k20" specs with the larger u-joints on the whole shaft. I tried to find one in a parts yard but no one local has it - most say they used forklifts to move them around so the shafts get destroyed by them. I was going to get one just so I could get the slip yoke off it.
The shop making the driveshaft doesnt have slip yokes he said, just makes the shaft.
Can someone point me to a replacement slip yoke I can buy online to have shipped to me, I tried ebay without luck.
Mattchu60 is offline   Reply With Quote
Old 09-11-2017, 02:04 PM   #2
sweetk30
sweetk30's Avatar
Re: Need a slip yoke for K20 - anyone know the right one to order?
this guy is local to me and good seller . i have got lots of stuff from him .
buy this and just have your guy shorten the shaft if it even needs to be shorter .
being the th400/208 combo is around the same length as your 700r4/208 combo you might get super lucky .
http://www.ebay.com/itm/M1008-DRIVES...cAAOSwPhdU2jIL
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 09-11-2017, 03:51 PM   #3
Mattchu60
I think that may work. Thanks for the link!
Old 09-11-2017, 06:16 PM   #4
sweetk30
sweetk30's Avatar
the m1008 is the military k30 truck . should work just fine in the price point . and always cheeper to shorten a shaft than retube and lengthen them .
