Old 09-11-2017, 09:55 PM   #1
mehoff400
250 power steering bracket
i bought these brackets used... either i cant figure out how the main bracket bolts on or its the incorrect bracket is it possible integrated head bracket?
66 c10 patina 250 T-5
My truck
mehoff400 is offline   Reply With Quote
Old 09-11-2017, 10:59 PM   #2
Backpayne
Re: 250 power steering bracket
The biggest piece/main pump bracket doesn't look right. Needs to bolt on to thermostat housing.
See the picture below.
Backpayne is offline   Reply With Quote
Old 09-11-2017, 11:08 PM   #3
Backpayne
I just ran out to take a picture of mine. I am missing just one piece to have the full set.
Old 09-12-2017, 12:12 AM   #4
rvrfoot
You can look in the search for the 250 power steering pump bracket pictures?
rvrfoot is offline   Reply With Quote
Old 09-12-2017, 07:09 AM   #5
padresag
here is one together and the bracket by itself
ron
padresag is offline   Reply With Quote
Old 09-12-2017, 07:38 AM   #6
mehoff400
Thanks for the help... ya the main bracket seems to be incorrect
My truck
Old 09-12-2017, 09:47 AM   #7
Lugnutz65
Lugnutz65's Avatar
Here are my brackets. Came off a 250ci and currently on my 230ci.
Also a video HERE.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 09-12-2017, 10:14 PM   #8
aotte1
Also another thread something like "292 power steering......" by
Aotte1, that you can advanced search on. The brackets are the same for both 6 cyl engines.
Les
aotte1 is offline   Reply With Quote
Old 09-13-2017, 11:28 AM   #9
jrusher
Which pump are you guys using and wondering where to get the pulleys needed? Im adding ps to a friends 6cyl 250 and will more than likely use aftermarket brackets off e bay
jrusher is offline   Reply With Quote
Old 09-13-2017, 12:31 PM   #10
Lugnutz65
Lugnutz65's Avatar
Pulleys for the fan/water pump and crank are fairly easy to find on eBay. The 230 and 250 use the same pulleys. Not sure about the 292.
The eBay version of the PS pump bracket eliminates the need for a double groove pulley on the alternator (I think).
As far as hoses go, I had a terrible time finding the right high pressure PS hose. I had a 1974 1/2T GM truck PS gear box (SAE fittings) and a 1969 PS pump (SAE fittings). I could NOT find a high pressure hose that had the correct fitting for BOTH ends. Then by dumb luck, the NAPA parts store sold me a hose that was perfect. I needed to make two 90 degree bends in the metal hard line and it looks like it was made for it. Correct length and everything. See pics.
So save this info if you have an inline 6 and plan to connect a PS pump to a PS gear box and are having trouble finding the correct high pressure line.
Old 09-13-2017, 12:37 PM   #11
jrusher
Great info thx !
As far as hoses go, I had a terrible time finding the right high pressure PS hose. I had a 1974 1/2 GM truck PS gear box (SAE fittings) and a 1969 PS pump (SAE fittings). I could NOT find a high pressure hose that had the correct fitting for BOTH ends. Then by dumb luck, the NAPA part store sold me a hose that was perfect. I needed to make two 90 degree bends in the metal hard line and it looks like it was made for it. Correct length and everything. See pics.
Old 09-13-2017, 02:37 PM   #12
mehoff400
Also able to find power steering pump pulley on rock auto
My truck
Old 11-03-2021, 08:59 PM   #13
72BBGMC
Hi, I know this is a really old thread but I found it trying to identify the same main power steering bracket. Did you ever figure out which 6 cylinder engine it fits?
Thanks, Mark
72BBGMC is offline   Reply With Quote
Old 11-03-2021, 09:20 PM   #14
padresag
Thanks, Mark
still have it. supposed to be for a 250
ron
Old 11-03-2021, 09:44 PM   #15
72BBGMC
Did you buy those brackets for a non-integral head 250 and it didn't fit? It looks more like an integral head type bracket but it is different from the ones I've had in the past. I don't have any 6 cylinder engines to do a trial fit.
Old 11-03-2021, 11:18 PM   #16
padresag
Bought it for a 250 and then sold the vehicle so I still have it. The assembled one is the one I have. I sent the lone piece back to the guy I got it from
