![]() Join Date: Sep 2002
In the process of rebuilding the front end of my 67 & about to order new ball joints. I see a lot of folks use Moog K6023 & K6024. In looking over the description of these it mentions they are "problem solvers". Specifically the lowers are "Oversized housing for a more secure fit". I understand that with worn control arms these would be needed, but mine still have the original ball joints & do not have any wear.
So should I go ahead with the K6023 for the lowers if I dont need an oversized housing ball joint? Also considering a set of ACdelco ball joints that are standard size. Any info is greatly appreciated. Thanks
1963 C10 swb fleetside 1966 GMC G1000 Handi-bus (future project) 1955 Chevy 2 dr. wagon |
Re: Looking for advise on ball joint selection
Pretty sure the K6023 is the MOOG lower part number and it is original fitment. The problem solver tag doesn't affect fitment.
K6024 is MOOG upper for the '67-'70 Be sure your truck has the original '67-'70 spindles ( drum brakes ) or these will likely be the wrong ball joints. Hth, -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
Thanks klb, pretty much have all that down, just wondering about the lower ball joint as being advertised as oversized. Also realize they r used when the original a arm hole has been altered due to previous issues, but mine r ok.
Who Changed This?
![]() Join Date: Jan 2013
If you have to press the old lower ball joints out, your a-arms are fine and can accept the standard replacement part. They are riveted in from the factory, and seldom will wallow out the hole- that riveting process makes 'em good and tight.
#5 | |
Junior Member
![]() Join Date: Jul 2014
Thanks guys
