straight 6 intake exhaust clamp?
Im missing an exhaust /intake bolt with this piece on it that holds intake and exhaust manifold to the head. cant find it anywhere. It came off a 1968 c10 4.1l 250
![]() Last edited by LockDoc; 09-12-2017 at 11:32 PM. Reason: Removed WTB |
Re: straight 6 intake exhaust clamp?
If you cannot find any, one can be made from a piece of 1/2" thick bar stock. Max torque on those is only 30 lb-ft. Have done it more than once.
1969 c-10 Step Side Long Bed. I-6 250cid = ![]() |
Does anyone know what it called?
Do you have all the clamps except one long style? below are a couple of old threads about the clamps. I wouldn't bother replacing any of the missing bolts. NAPA should have studs that fit for a much easier installation. There should be two studs now in the 3rd hole, in from each end. Head rebuilders often remove them and don't replace.
http://67-72chevytrucks.com/vboard/s...d.php?t=374618 http://67-72chevytrucks.com/vboard/s...d.php?t=454785
'67 GMC 2500, 292, 4spd, AC |
![]() Join Date: Feb 2002
Thanks to all I'm fabbing some 1/2 inch. Figured I could test my skills
thanks for the help guys get her fixed up and sounding normal again !
Maybe use an old chevy rocker arm flipped backward?
I have used the high-grade alloy steel pivot ball -- flipped around -- to secure the end bolts on L6 headers. Studs hold the stock manifold in that set up.
