09-12-2017, 05:52 PM | #1 |
Turn Signal switch housing
Stupid question but I have been fighting with this turn signal switch housing for a while now and I can't seem to get it back on. Anyone have any tips?
09-12-2017, 07:12 PM | #2 |
Re: Turn Signal switch housing
They can be a little fussy sometimes. Here's a thread I did a while back when I was working on my column:
http://67-72chevytrucks.com/vboard/s...d.php?t=711090 Be patient, you'll get it.
Dennis '70 CST/10 '55 Bel Air wagon |
09-13-2017, 12:15 AM | #3 |
I Finally got it. Thank you sir.
09-13-2017, 10:59 AM | #4 |
Outstanding. Glad you got it going.
09-13-2017, 05:19 PM | #5 |
So I guess I lied. The housing will not go down all the way as you can see in the picture. Also I can turn the housing by hand with everything installed and the shift indicator is way off. Any idea on what I can or should do to get this correct. I have been at this for two days now and its pretty frustrating as this should be a pretty straight forward job. Any help is appreciated.
09-14-2017, 04:08 PM | #6 |
Looks like the rubber spacer is causing it to sit uneven for some reason.
09-14-2017, 05:04 PM | #7 |
In your first picture you can see the rubber cone shaped washer, it's sitting out too far, it rests on a white plastic washer that has an outside key way, I bet the plastic washer is not located in the outer column slot.
Which I assume prevented engagement of all 3 tangs on the turn signal switch cover to the outer column. |
09-19-2017, 04:11 PM | #8 |
Does anyone know where I can get one of these rubber spacers?
