Old 09-12-2017, 06:56 PM   #1
Kcabbie72
Looking for a local shop for trans swap
I am wanting to have a overdrive trans installed. I have decided on a 4l80e with the TCI EZ controller. I'm currently located in Towanda PA. Anyone know of a local shop within a hour or two that can source a good trans and do the swap for me? Thanks for any help!
1972 Chevrolet C-10 Highlander - 283 v8, Th350
1984 Chevrolet C-10 Custom Deluxe - straight 6 with a 3 on the tree
Kcabbie72 is offline   Reply With Quote
Old 09-12-2017, 07:53 PM   #2
old51sedan
old51sedan's Avatar
Re: Looking for a local shop for trans swap
If your running a 283 with a 350 turbo you may want to consider a 200-4R. I just had one built for my truck. It's almost an exact replacement for your 350. Same length, just move trans mount back about 5". No need to redo the driveshaft, same length and will bolt right up to your motor. Just a thought! Good luck
old51sedan is offline   Reply With Quote
Old 09-12-2017, 08:08 PM   #3
Kcabbie72
Thanks for the response! I should update my signature. In the last 4 weeks I've installed a blueprint 383. I want to go the 4l80e route because of its tuning capabilities with the tci unit. Also I really want something that has lock up so that I can have a high stall without loosing the ability to have good hwy manners.
Old 09-12-2017, 09:40 PM   #4
Mike C
Mike C's Avatar
The TH200 4R has lockup capability. And you don't have to spend thousands of dollars on the controller. A built, 500hp TH200 4R can be had for under $3k. While the 4L80E and controller is something like $7500?
FWIW, I am buying an Extreme Automatics TH200 4R to put behind the 427 big block in my 69 short step.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 09-13-2017, 07:37 AM   #5
Kcabbie72
The tci controller is onlying 700. Look up the YouTube video about all the settings it's very adjustable. No kick down cable either
Old 09-13-2017, 08:42 AM   #6
Mike C
Mike C's Avatar
You will love OD no matter which way you go. If you find a clean, low mileage 4L80E from a wrecking yard and the controller only $700 that seems like a viable choice.
But IMO, the gear ratios, size, mechanical speedo, of the TH200 4R is the best choice for me. Good luck with your truck I look forward to seeing which way you went.
FWIW, I wouldn't even consider a TH700R4. I absolutely DESPISE the 1-2 drop in that trans. Now a 6 speed....
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 09-13-2017, 08:45 AM   #7
old51sedan
old51sedan's Avatar
Mike, sounds like the man has got is mind made up. I guess that's not all bad, but the 200-4R is a good trans and an easy swap. There also getting harder to find.
Old 09-13-2017, 09:06 AM   #8
Kcabbie72
Hope I don't seem hard headed. I considered a 700/200r4 but the lockup has to be on a switch if you want it to lockup under OD. This is my wife's truck and I don't want her to be worried about anything besides driving it. That tci controller will lock up above X speed and unlock at wot. It also has automatic control over how firm the shifts are in "normal" and in "performance" modes. Also it would work well with Dakota digital gauges with the 100$ module that sends information such as Trans temp and VSS.
Does $600 for labor seem hi to do the swap?
Thanks for everyone's input!
Old 09-13-2017, 09:51 PM   #9
Mike C
Mike C's Avatar
I wouldn't do it for $600. Not if it meant all of the work involved. Moving mounts, wiring, measuring and getting a driveshaft, etc. So sounds like a good deal to me.
44 Willys MB
52 M38A1
64 Corvette Coupe
