Old 10-27-2003, 08:35 PM   #1
68chevytn
van steering column questions
i was at the junk yard the other day and i seen one. i have a couple questions. 1st do u have to have the ignition on the colum if u use one? 2nd what do u have to do to it to get it to work? 3rd what years will work?
chris
68chevytn is offline   Reply With Quote
Old 10-27-2003, 08:46 PM   #2
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
1. Ignition on column: NO you don't have to use it.
2. Shorten your collapsible shaft (The Double D Shaft) By drilling out the nylon Rivets. Move the neutral saftey switch if it's mounted high on the shaft. And you can get a wiring adapter for the U-shaped plug to the flat , if you need the part # I Have it. Other than that I can't think of anything else. It's been a while since I put one in my truck.
3. Early 70's to I think '87, I can't remember right off hand.
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 10-28-2003, 12:02 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
You're best off getting one with no ignition switch on the column. They are way easier and look original. They go from 69 or 70 up to 81 and a hand full of 82 vans.
No need to drill out the nylon rivits, they will break if you tap the shaft with a hammer.
Old 10-28-2003, 12:13 AM   #4
minibike
minibike's Avatar
Anyone have the specifics on the nuetral safety switch? How do you relocate it?
69 SWB
LT1/4L60E
www.classicplace.com
minibike is offline   Reply With Quote
Old 10-28-2003, 09:40 AM   #5
smokekiki
Mike
smokekiki's Avatar
Try this thread....http://67-72chevytrucks.com/vboard/s...threadid=58950
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
