Old 09-13-2017, 11:45 PM   #1
neverfinished52
neverfinished52's Avatar
47-53 taillight bracket without license plate
I don't need the license plate bracket on the drivers side so do I just get 2 passengers brackets and mount one backwards on the drivers side? Thanks
neverfinished52 is offline   Reply With Quote
Old 09-13-2017, 11:51 PM   #2
joedoh
joedoh's Avatar
Re: 47-53 taillight bracket without license plate
you can get two passenger brackets but you will need to drill out the rivets and flip the bracket over and rerivet or weld it, I did it on my 49 build and it worked perfect (I welded the rivet holes)
if you buy the one with the licence plate holder you can just drill out the rivets in the plate holder and remove that piece, the brackets are mirror images and the plate holder theroetically could be added to either side.
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
