![]() Join Date: Oct 2013
Rear Traing Arms Install?
Getting ready after rebuild to install the rear trailing arm. Is their any symmetry difference in them, as to which goes on one side or other. Front bushing flange faces in or out? First coil spring rear.
Thanks Les Last edited by aotte1; 09-15-2017 at 02:58 AM. |
![]() Join Date: Jan 2011
Re: Rear Traing Arms Install?
Les they have a bracket on them for the Ebrake and that faces out.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
Jimmy,
These trailing arms seem to not have that bracket? Is it bolted or riveted on? A few pic of trailing arms. Thanks, Led |
Pic
Pic2
More pics, maybe area where e brake bracket was?
Do 66' have same bracket as 65? |
Les your missing the brackets so from what I remember they are the same trailing arm and will fit either side. The stockcar products arms that I had in the 65 were the same and I added the brackets off my old rusty arms.
Jimmy
Jim,
Thanks,will be looking for some brackets. Les |
