Old 09-15-2017, 09:24 AM   #1
SLDPULR
SLDPULR's Avatar
My disc brakes on the cheap
I just wanted to share my 12 bolt disc break install. I have read lots of threads where people had started this but I havent seen one that actually finished it.
Parts list:
Caliper brackets: http://www.speedwaymotors.com/Weld-O...cket,3348.html
LH Caliper: https://www.oreillyauto.com/detail/b...rwd?q=brake+ca
RH Caliper: https://www.oreillyauto.com/detail/b...rwd?q=brake+ca
Rotors: https://www.oreillyauto.com/detail/b.../astro?q=rotor
Brake pads: https://www.oreillyauto.com/detail/b...rwd?q=brake+pa
Break line: http://www.rockauto.com/en/moreinfo....030565&jsn=470
Cost came out to $201.57 for the 12 bolt side, I still haven't done the new proportioning valve yet. I have the 600HP Fitech sitting on my kitchen table and I'm waiting to see how much vacuum my engine will pull before I decide on my new master cylinder. The XE294H cam only pulled 8" of vacuum with the Holley 750 DP so I doubt it will be enough to run my booster.
Calipers are 1980 D52 front calipers, Rotors are 1999 AWD astro van rotors, Break lines are front lines from a 1980 c10. If I do it again I will clock the rotor more in the 9 o'clock position and I still need to fab a bracket to hold the brake line. Hope this helps someone down the road.
1980 TURBO C10
(GRUMPYC10 ON INSTAGRAM FOR MORE PICTURES)
SLDPULR is offline   Reply With Quote
Old 09-15-2017, 10:48 AM   #2
Moostifer
a fool with no money
Moostifer's Avatar
Re: My disc brakes on the cheap
doing away with the E brake?
Basicly stock 83 SWB with a few Bolt-ons
before, during and still during
http://photobucket.com/albums/y251/moostifer/truck/
http://photobucket.com/albums/y251/moostifer/motor/
Moostifer is offline   Reply With Quote
Old 09-15-2017, 12:49 PM   #3
SLDPULR
SLDPULR's Avatar
Yes, If it was a daily driver or a manual I would be a little more concerned about not having an E-brake, although if there was an easy way to add one I wouldn't be opposed to it.
I feel like I have seen an aftermarket d52 caliper with a e-brake lever on it so if anyone knows of one let me know.
1980 TURBO C10
