Old 09-15-2017, 10:57 AM   #1
WyattTX
Door shell difference?
I notice suppliers list 73-76, and 77-87 door shells. Aside from the interior panel, and hardware they all look the same to me. So according to these suppliers I can stick a 77-80 door panel on an 81-87 shell, and vice versa. Why cant you interchange these parts with the 73-76 doors? Thanks.
WyattTX is offline   Reply With Quote
Old 09-15-2017, 02:17 PM   #2
Prong
Re: Door shell difference?
The window regulator is different as well. They were redesigned in 77 to accommodate power windows. FYI, the Blazer and front doors on the Suburbans up to 91 are the same as the trucks.
Prong is offline   Reply With Quote
Old 09-15-2017, 02:25 PM   #3
Desert_Eagle02
73-76 doors have a bit different internals and the metal stamping on the interior side of the door is different. It is made for the smaller door panel and the metal is "raised" around the panel. Pretty sure the vent window assembly is different as well, but I don't know if those will easily swap between the 2 styles.
1978 GMC K25
1984 Chevy Scottsdale K10 built 350 4"lift - SOLD
Desert_Eagle02 is offline   Reply With Quote
Old 09-15-2017, 02:29 PM   #4
WyattTX
Thanks, I have always wondered about this. Do the same rules apply for the rear doors on crew cabs, and Suburbans?
Old 09-16-2017, 06:07 PM   #5
Pontiac1976
Pontiac1976's Avatar
http://bowtieguy.proboards.com/threa...-87-break-fits
This may help
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 09-16-2017, 09:57 PM   #6
franken
There are billions of rust free square doors in southern scrapyards, and I'd buy used. Aftermarket parts are the last resort. I'd simply do a search and look at pics to see if an 89-91 part is right. Blazers, subs, and probably crews changed in 92. A part search is a good way to think for yourself, rather than trust the opinions of others.
Anyone want me to start a business shipping rust-free doors/hoods/fenders/botlton parts for squares?
franken is online now   Reply With Quote
Old 09-17-2017, 01:07 PM   #7
WyattTX
Originally Posted by Pontiac1976 View Post
Thanks, that helps a lot. The interior skin is the only major difference, it appears.
Old 09-17-2017, 08:23 PM   #8
Big Port Jimmy 6
Addicted to Rust
Big Port Jimmy 6's Avatar
There ain't as many as you think.
Current trucks:
(48 GMC100 320 inliner) Gone
(48 Suburban in pieces) Sold
87 GMC CCSB 5.3 4l60E Daily Driver
ECTA National record holder XO/PP
We never really grow up, we just learn how to act in public.
Big Port Jimmy 6 is offline   Reply With Quote
Old 09-20-2017, 11:59 AM   #9
Aaron Burkemper
Aaron Burkemper's Avatar
So if you swap out the whole door, interior panels included, you are good to go?
1971 C20 "Shreck"
1980 C30 dump bed "Ratchett"
Aaron Burkemper is offline   Reply With Quote
Old 09-20-2017, 04:37 PM   #10
WyattTX
Yes, but it would probaly look out of place, unless you changed the dash pad and guage bezel too. If you need doors for a pre 77 truck, you can weld the interior skin of 73-76 do on to the shell of a 77-87 door shell (or 73-91, with burbs blazers, and crew cabs.) So you can still use the early door panels. 73-87 cabs are all the the same, so if you do not care about cosmetics, doors from all years should interchange with no problems.
