Old 09-16-2017, 11:03 AM   #1
bhayes1
bhayes1's Avatar
AC Compressor - Factory or Aftermarket
Looking to get some info on this A/C compressor. Is it factory or aftermarket. My guess is it was a dealer installed option. The truck is a non-AC Cab with a under dash air unit. Is it desirable or worth anything?
Also, Can you help me confirm this Tranny. Th350 or 400? I was trying to ID it by the pan, but I'm still not quite sure.
1969 GMC K2500
bhayes1 is offline   Reply With Quote
Old 09-16-2017, 11:11 AM   #2
AussieinNC
Moderator
AussieinNC's Avatar
Re: AC Compressor - Factory or Aftermarket
Trans is th350
A/C is aftermarket kit, does it work?
AussieinNC is offline   Reply With Quote
Old 09-16-2017, 11:39 AM   #3
bhayes1
bhayes1's Avatar
All hoses are hooked up and the pulley isn't frozen - spins freely. I'd probably give it a once over before putting it on anything or back into service but it appears to be all there.
Thanks for the help on the tranny.
1969 GMC K2500
Old 09-16-2017, 12:42 PM   #4
F.A.A.benny
The compressor is a York. These were aftermarket on GM but factory in Fords
F.A.A.benny is offline   Reply With Quote
Old 09-16-2017, 02:05 PM   #5
68Gold/white
Those are good compressors. You may have some work ahead of you if you try to get the AC working properly.
68Gold/white is offline   Reply With Quote
