Squarebody rear end in a 66
Okay y'all, from what I have searched would a squarebody rear end fit in a 66'?
Truck is GMC so we plan on moving leaf spring perches and I've found it's 1.5" longer. Is this true? Are there any other problems? Thanks. |
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
Re: Squarebody rear end in a 66
Yes it will. They are 1.5" wider than your 66. GM changed to a 10 bolt sometime in mid/late 80's and it would also work. You will need to chop the spring perches off if your 66 is coil sprung. Capt fab has coil mounts for you. Good luck!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Nope got leaf springs on the 66, gonna try and find a square boy one rear end. Get new perches for em, and instal a posi. Thanks for the help!
