Old 09-18-2017, 01:07 PM   #1
1badmonza
1badmonza's Avatar
Rear End Clearance
What is the minimum clearance you can have between the frame and top of rear end on a 68 C10? I have about 3" now and want to lower it another 1-1/2". Do I need to go ahead and do a C notch kit?
1badmonza is offline   Reply With Quote
Old 09-18-2017, 01:30 PM   #2
Jcfcamaro
Jcfcamaro's Avatar
Re: Rear End Clearance
I'd say yes, because if you haul anything with any weight you'll be out of travel and be bottoming out .
Jcfcamaro is offline   Reply With Quote
Old 09-19-2017, 10:18 PM   #3
Mike C
Mike C's Avatar
I flipped the leaf spring rear in my 69 and it dropped it just over 7". I have about 1 1/2" between axle housing and frame. I put the 3/8" thick urethane "pad" on the frame above the housing and I removed the factory bump stop steel pads on the housing.
I have no problem loading several hundred pounds in the bed, but it does hit the bump stops on big bumps.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Mike C is online now   Reply With Quote
Old 09-20-2017, 08:44 AM   #4
1badmonza
1badmonza's Avatar
Thanks for information. I'm gonna have about the same amount of clearance. Where did you get the pads for the frame?
Old 09-20-2017, 09:15 PM   #5
Mike C
Mike C's Avatar
They came with the DJM kit. They are a urethane puck with a 1/4" stud on the back.
44 Willys MB
52 M38A1
64 Corvette Coupe
