1987 Chevy V20 nine year slumber
I picked up a 1987 Chevy v20 that has sat for 9 or 10 years because of freeze plugs were rusted out , I replaced the head gaskets because I had to pull the drivers side head to fix a broken exhaust manifold bolt ( i cant stand exuast leaks ) so I figured I would do both head gaskets , here is the parts list so far .
Head gasket set Exhaust manifolds R/L Front brake hoses R/L New gear reduction starter Rear brake hose Distributor cap and rotor Plugs Plug wires Freeze plugs Clutch master cylinder Clutch slave cylinder Clutch hose Radiator Coolant hoses upper and lower Thermostat Parts needed Front brake calipers Brake master cylinder And more I am sure
1985 Chevrolet Custom Deluxe 4x2 , 305 v8 , 700R4 transmission |
Re: 1987 Chevy V20 nine year slumber
Sounds like that truck is getting some much-needed care. Nice work. Got some pics for us?
