Who Me?
97 Tahoe Ignition Lock replacement
The black plastic that surrounds the key and gives you leverage to turn the key broke off in my hand today. When I look up this part is says that "PART REQUIRES CODING AT GM DEALERSHIP". Im almost 100% sure this key does not need coding.. I wanted to confirm with you guys on that. For instance. I have a replacement key that is just flat metal. No plastic, no chip or anything and it works fine.
Steve1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
Old Heap Driver
Re: 97 Tahoe Ignition Lock replacement
I have a 97 Yukon, Tahoe's cousin, anyway, I have a spare key, flat metal, works just fine.
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
Who Me?
Replacement part came in today.. Planning on replacing it this weekend. Thanks for the reply.
![]() Join Date: May 2006
I replaced mine on the '97. YouTube videos are extremely helpful. Check them out. I was able to get the little tumbler springs and retaining plate at the dealer. I pulled the tumblers out with some heavy-duty tweezers. It worked pretty well. I also replaced the upper and lower plastic "clam-shell" while I was at it since the top part was broken on mine.
1989 K1500 Chev. EC Original owner; some of the aftermarket parts I've installed are Borla headers, Hypertech chip, Edelbrock water pump, and a Stillen rear disc brake conversion kit. 2009 Hummer H3T 3.7L 5M (sold) 1997 K2500 Chev. EC 7.4L/ 4L80E (sold) 2018 Dodge Ram 2500 HD R/C |
| Bookmarks |
