09-19-2017, 10:07 PM | #1 |
2002 to 2006 seat interchange
Have been doing some searching on updating the bench seat in my 1986 pick up. Read where the 92 style seat go in but have to do quite a bit of reworking on the tracks. Has anybody used the 2002 style seat or the same problem. They are extremely comfortable maybe there is something else that someone has used.
09-20-2017, 09:30 AM | #2 |
Re: 2002 to 2006 seat interchange
I put the bench from a 99 Tahoe in mine. It should be the same as what your asking for. It's probably the most comfortable of the 3 or 4 seat combos I've used over the years. I believe all I used was the a shaped tabs up front and bent the rear of the brackets to fit the floor.
1978 Scottsdale - celebrating 10 years of teaching me profanity 1990 Silverado - bought in Nov. 2016 and it's already catching up - Sold 1987 k5 blazer - sold... :\ seed money for the 81 1981 k20 4x4 - 5.3 swap in progress Events attended: Spring GOG 2011 Dale JR car show Summer 2012 Gathering at Tommys pickup parts |
09-20-2017, 09:42 AM | #3 |
biggest problem with retrofitting the newer seats in older trucks is Chevy went to the flat floor in 88 with the new models. so most seats are going to require some fabrication of mounts into the 87 and older trucks
09-20-2017, 10:08 AM | #4 |
I have been eying some 2002 seats too. They are leather buckets with the built in arm rest and seat belt. They look to me like they would fit, with some mods of course. I probably won't bite this time around but they sure got me thinking again.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
09-20-2017, 06:50 PM | #5 |
I used seats out of an early 90's Cadillac DeVille. They fit in our trucks as if they were made for them.
09-21-2017, 06:32 AM | #6 | |
I like the shoulder belts in the 2002 seats because my truck doesn't have shoulder belts.
09-21-2017, 06:52 AM | #7 | |
I have a passing fantasy of trying to find one and fitting it into a C10. Mike |
09-21-2017, 07:53 AM | #8 | |
Yes they are extremely comfortable, low back and good for long trips. The width is slightly incorrect for use as a bench seat but they can be easily converted to bucket seats by removing the center section out. They then are the perfect width for using a center console or use in a Blazer or Suburban. |
09-21-2017, 10:37 AM | #9 |
I used the same thing around 1994 seats. Had to make custom brackets but they fit well and are super comfortable
AZPartsLocators on Instagram 1972 Cheyenne Super Short Bed big block "Blackie" 1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog" 1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck. |
09-22-2017, 07:30 AM | #10 |
I have installed a 1996 Silverado seat in my 65 Pickup and it was a breeze. Outside bolt holes were exact but it was a 60/40 split so had to drill my own inner mounts. They are a real nice seat as well.
09-22-2017, 09:31 AM | #11 |
Cadillac seats don't usually fold forward. I'll have to see how far they can recline forward. From my research the 90's truck sets seem to be the best fit. They fold forward and give some head/neck protection.
09-22-2017, 01:02 PM | #12 |
The 2 door eldorado seats do fold forward. Quite a few of them around. Super comfortable and look like they are meant to fit in a square
09-22-2017, 01:13 PM | #13 |
I swapped out the bench seat for some seats out of a 01 or 02 Silverado into our '69, primarily for the shoulder belts but also the comfy/cupholder/console benefits.
As I recall, I had to drill holes in the middle of the cab floor for the inside seat rails and the console, then stacked washers under a couple of the front corners to level it all up. One thing - The new seats moved me a tiny bit up and closer to the steering wheel, enough that the original manual steering wheel was right in my lap. I've since replaced it with a later/smaller wheel with power steering, so it's all good now - they fit, although I can't move them any farther back because of (1) the gas tank, and (2) the headrests would be hard up against the rear glass. BE SURE and use at least Grade 8 bolts and LARGE washers under the floorpan - you don't want that seat pulling out in a crash.
My Chevy Truck Project Build Thread '62 Ranchero - 200 I6, 3-on-the-tree, power nothing. '71 LeSabre - 455 Stage 1, power everything. Last edited by jamyers; 09-22-2017 at 01:21 PM. |
09-22-2017, 02:43 PM | #14 |
I had a 90 coupe deville..Those seats were super comfortable. I often wondered if they would fit in my truck.
09-22-2017, 03:44 PM | #15 |
