Old 10-28-2003, 12:27 AM   #1
cranknut67
cranknut67's Avatar
conversion DONE! / drum to disk-need advise
I just converted the '67 drummer to '77 disks and power brakes - what do I have to do to get drop spindles? - do they make a 7/16 drop spindle for 6 lug 7/16 lugs so I can use my old Weld rims?
BTW you should see the truck - looks like a baja truck all lifted in the front. - it's so sweet to finally upgrade to the 70's
later..
cranknut67 is offline   Reply With Quote
Old 10-28-2003, 12:53 AM   #2
crazy longhorn
Fabricate till you "puke"
You can use dropped spindles for the 73 up, & if you have the thick rotors(1.250), you can get aftermarket 6 lug rotors. You might talk with GMC Paul, or Wes on the details(im not sure on the stud size). Good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
