Old 09-21-2017, 05:20 AM   #1
In The Ten Ring
Can anyone post a pic of how the OEM battery clamps down?
I am finally nearing the end of my rebuild but I don't have a clue how the battery clamps down into the battery tray.
I'll be using OEM battery tray hardware, can someone hit me with a pic?
In The Ten Ring is offline   Reply With Quote
Old 09-21-2017, 07:24 AM   #2
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Can anyone post a pic of how the OEM battery clamps down?
Battery sits in the tray and this piece bolts it into place on motor side. It fits the lower part of the battery side.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 09-21-2017, 07:44 PM   #3
Curtb1971
Curtb1971's Avatar
Here is the clamp installed on the battery. I thought the clamp went the other way (flipped) when I first put it in.
Curtb1971 is offline   Reply With Quote
Old 11-12-2017, 09:36 AM   #4
Hotcorner
Hotcorner's Avatar
Is this correct?
1969 GMC K25
2007 Chevy 2500HD Classic Duramax
1999 Tahoe 2DR 4WD Base Model 5.7l
Hotcorner is offline   Reply With Quote
Old 11-12-2017, 09:44 AM   #5
FRCvette
Originally Posted by Hotcorner View Post
Is this correct?
That is the way it is on my 70 too.
There's something women like about a pick-up man
1967 c10 swb Stepside
2004 SSR
2013 Silverado swb
FRCvette is offline   Reply With Quote
Old 11-12-2017, 11:10 AM   #6
Hotcorner
Hotcorner's Avatar
Is this correct?
1969 GMC K25
Old 11-12-2017, 11:24 AM   #7
jjzepplin
jjzepplin's Avatar
That's what I've got on both my trucks.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 11-12-2017, 02:09 PM   #8
In The Ten Ring
Wow those pics are great, thanks!
What a great way to hold a battery down..........much less in the way at the top.
Old 11-12-2017, 02:35 PM   #9
Hotcorner
Hotcorner's Avatar
Replaced the broken battery tray and now bolt doesn’t reach the nut on mine. Maybe it’s not the right bolt
