Wiring 1966 C10 6cyl
Hi All,
I am having an issue with wiring. Some background. I have a 1966 C10 that HAD a 292 my brother removed 20yrs ago or more. A lot of the wires were just cut. I have recently got a 230-250 from a what I believe was a 1961, never saw it in the truck. So, I can't match up what I am seeing in the wiring diagrams (here) to what I see in the engine bay. Please see attached image of the starter side of the motor. The coil to starter is a red wire, to far side post. Then I have a bundle from the firewall that are Green and Dark Green (I think they go to thermal sender), then a yellow and grey or brown. Then that loon splits later to a Purple, Yellow and Blue. Purple I believe goes to far side of starter as well, but what about the others? Any ideas? Also, the alternator/generator had most of the wires, but I don't know what should go to the post on bottom right, old cut off wire is still there. At this point, I really would just like to try and start the motor, not sure if the purple to starter with the coil wire are enough with the others I have. Thanks for any advice. -n |
Moderator
![]() ![]() Join Date: Aug 2011
Re: Wiring 1966 C10 6cyl
Hopefully a member named VetteVet will come along, he's really good at electrical systems. He hangs out in and I would ask there if I were you - Here - http://67-72chevytrucks.com/vboard/f...splay.php?f=64
If you dont ask vettevet ain no body gonna talk to you bra ![]()
