Old 09-23-2017, 01:22 AM   #1
andrewpclayton
andrewpclayton's Avatar
Squeak in the front end
There is a squeak that is like a fluttering chirp in my front end somewhere. It happens only when the compression of the engine is slowing the truck down, and my foot is off the gas. If i give any gas at all, it stops, and if I put it in neutral it also stops.
From what i can tell, its not in the dash.. not anything i can reach and hold secure.
I cant reproduce the sound in any way other than driving.
I did try to clean underneath the truck with degreaser.. around the trans and brake area
Does this sound familiar to anyone?
1977 SWB (c20 conversion) SBC350
Springfield Oregon
Instagram: @nevernotchevy
andrewpclayton is offline   Reply With Quote
Old 09-23-2017, 10:02 AM   #2
Warrens69GMC
Warrens69GMC's Avatar
Re: Squeak in the front end
have you lubed your control arms lately?
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 09-23-2017, 01:18 PM   #3
Wrenchbender Ret
It could possibly be an engine mount or trans mount. If the rubber is wallerd out the metal can contact the bracket Or frame.
Wrenchbender Ret is offline   Reply With Quote
Old 09-23-2017, 04:35 PM   #4
AussieinNC
Moderator
AussieinNC's Avatar
Sounds like universal joints need some lube...if the universal joints have grease nipples, give em a good shot of grease...
If they dont have nipples, its possible one or more are ready for replacement...
If you replace em, get joints with grease nipples...
AussieinNC is offline   Reply With Quote
Old 09-23-2017, 04:53 PM   #5
bill3rail
bill3rail's Avatar
Lubricate the crap out of one thing at a time then drive a few miles until it disappears or changes. It should be one of the last items lubricated.
1970 C10 8' Fleetside, L6 250, 3 on the Tree.
The most basic of pickup trucks!
bill3rail is offline   Reply With Quote
Old 09-23-2017, 05:15 PM   #6
andrewpclayton
I greased every nipple I could find in the front end, and we got the headers away from the frame. Guess we’ll try engine and trans mounts next
Springfield Oregon
Old 09-26-2017, 12:10 AM   #7
andrewpclayton
Here is a video of the sound..To be honest I’m not sure it’s even in the front end.. it’s so annoying!
It’s only when engine compression is slowing truck down.. any gas at all or neutral makes it stop.
Also I broke the fuel gage somehow when I took the cluster off too paint ugh
https://youtu.be/9WQTCSz63dI
Springfield Oregon
Old 09-26-2017, 01:37 AM   #8
Curtb1971
Curtb1971's Avatar
Maybe exhaust hangers? Have you tried wigglin the exhaust around. Also here is a link for troubleshooting fuel gauges.
http://67-72chevytrucks.com/vboard/s...d.php?t=640615
Curtb1971 is offline   Reply With Quote
Old 09-26-2017, 02:09 AM   #9
andrewpclayton
I don’t think it’s the exhaust hangers because they’re all installed with a rubber bushing between the metal of the hanger and the frame. I shake them and it doesn’t cause the sound.
Springfield Oregon
Old 11-29-2017, 07:40 PM   #10
andrewpclayton
I FOUND IT! Turns out it wasnt in the front end, but it was the carrier bearing, or possibly the U joints. the bracket that was holding the carrier bearing broke so i go that fixed, along with the drive shaft fixed because when it broke the ears on the yoke were all jacked up. $400 later new joints, new carrier bearing, drive shaft looks brand new, and the squeak is gone! ride quality is unspeakably better. so happy
Springfield Oregon
Old 11-30-2017, 12:26 AM   #11
dfwright
dfwright's Avatar
Cool beans! I think you meant "unsqueakably better" though,
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 11-30-2017, 12:27 AM   #12
andrewpclayton
Lol yep!
Springfield Oregon
Old 11-30-2017, 12:45 AM   #13
LockDoc
The Older Generation
LockDoc's Avatar
Thanks for following through with the solution. There are a lot of people that don't do that.... It helps others down the road.
LockDoc
Leon
Old 11-30-2017, 02:50 AM   #14
Curtb1971
Curtb1971's Avatar
LockDoc
X2, glad you got it tracked down and fixed
1971 LSX "Bonnie" build thread
http://67-72chevytrucks.com/vboard/s....php?p=8026381
paypal is curtbarton1971@yahoo.com
