? on head light
Just wondering what the best headlight set up that everyone is running and keeping it close to a stock look ,so it doesn't look like airplane lights ,searched forum but found old post thx for the help Hop
Save a tree support your local drag strip !!! |
![]() Join Date: Feb 2013
Re: ? on head light
I upgraded to Hella Vision Plus Conversion Headlights. Happy with the product and light output. Super easy install.
http://www.myhellalights.com/index.p...sion-headlamp/ $42 and change each from Summit or Amazon. |
Re: ? on head light
I think putting in headlight relays will give the most improvement in lighting. With the truck running and you get your 14 volts to the headlights put in what others recommend. I think I might have put in halogen but one burnt out so now one of each.
Moderator
![]() Join Date: Dec 2012
Re: ? on head light
Halogens, plus relay kit.
I still have T4s... I don't drive at night much, lol. I should trade someone. |
meowMEOWmeowMEOW
Re: ? on head light
I vote airplane lights
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
Re: ? on head light
I am interested in this topic, too. In addition to posting your bulbs, can someone please describe what I need to do w/r/t a relay? New to that kinda thing so really not sure.
1965 GMC 1000 SWB Fleetside L6 230 - SOLD Thanks everyone for the help over the years. |
Re: ? on head light
Go to the electrical forum and type in headlight relay. Lot's of stuff explained there and you'll have fun doing it.
Moderator
![]() ![]() Join Date: Aug 2011
Re: ? on head light
Some informative info on these threads:
http://67-72chevytrucks.com/vboard/s...d.php?t=397695
Re: ? on head light
Cibie H4 headlights are the best that look old (fluted glass lens). They have a better beam pattern than Hella H4's.
A relay harness will help as much as a good set of headlights. Do both a harness and Cibie H4's and you'll have better lights than modern cars with halogen bulbs, and better than some oem HID/projector headlights. Stay away from bulbs that have blue coatings as they filter out some of the useable light. ![]() Link to Cibie H4's. https://www.amazon.com/Cibie-082440-.../dp/B008DQV88Q Voltage drop/lumens chart. Just a little bit of voltage drop makes a big difference in brightness. ![]() Low beam shot of my Cibie H4's with a relay harness: ![]() High beam: ![]()
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
Re: ? on head light
I added relays and switched to Sylvania Silverstar lights. Very happy with the results.
Re: ? on head light
Search headlight and see what everyone is using.
