Old 09-24-2017, 04:33 PM   #1
bigbadchev72
People know me
bigbadchev72's Avatar
Fuel tank relocation options?
I have a cut down 68' SWB 2wd and a 4wd that are in the shop being built at the same time. I am kicking around the idea of getting the tanks out of the cabs.
I do not want to add a fuel door in the bedside, or cut a hole in the floor. So with those two being ruled out, what are my options?
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels
1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels
bigbadchev72 is offline   Reply With Quote
Old 09-24-2017, 04:35 PM   #2
bigbadchev72
People know me
Re: Fuel tank relocation options?
Also my 2wd is static dropped 4.5/5 and I will probably be doing another 1" drop in the rear once i am closer to driving it. How far below the frame rails do these tanks typically hang?
Old 09-25-2017, 06:33 PM   #3
bigbadchev72
People know me
Anyone?
Old 09-25-2017, 10:27 PM   #4
swatguy
You’re pretty limited. You need the filler hose to route somewhere. You could hide it behind a taillight. I have seen trucks that the taillight swings open to reveal filler. Look up c10 zl1.
I used a tank from tanks Inc. It is a tank for a late 50’s chevy. Not visable from rear. Holds 15 to 16 gallons. Hope this helps.
Pete
swatguy is offline   Reply With Quote
Old 09-26-2017, 06:42 AM   #5
SIXTY9
Look at this Thread http://67-72chevytrucks.com/vboard/s...d.php?t=448431 I am doing it to my 69.
SIXTY9 is offline   Reply With Quote
