Old 09-24-2017, 05:04 PM   #1
doubledoyle
Series 1 + 2 wheels difference
Hi guys
Anyone know if series 1 wheels will fit a series 2?
Cheers
Dale
doubledoyle is offline   Reply With Quote
Old 09-24-2017, 05:11 PM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: Series 1 + 2 wheels difference
are you referring to the 55 1st and 55 2nd?
both should be 6 on 5 1/2" bp...not sure of center hole..
Old 09-24-2017, 05:23 PM   #3
doubledoyle
Hi
I mean 47 - 55 wheels on a 58 apache
Cheers
Old 09-24-2017, 05:41 PM   #4
Dan in Pasadena
Dan in Pasadena's Avatar
Originally Posted by doubledoyle View Post
Hi
Cheers
Same-same. If you don't specify in your question what part of 1955 model year you're talking about. 1955-59 are ALL Task Force trucks, not "Series 2" anything.
1955 1st half of the model year were Advanced design trucks, 2nd half of model year were Task Force trucks the same as 1958-59.
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is online now   Reply With Quote
Old 09-24-2017, 05:49 PM   #5
doubledoyle
Cheers thanks for your reply. Sorry if I came across short it wasn't my
Intention.
First time chevy truck owner with plenty to learn
Old 09-24-2017, 05:56 PM   #6
dwcsr
Hollister Road Co.
dwcsr's Avatar
Intention.
Short answer is yes.
dwcsr is offline   Reply With Quote
Old 09-24-2017, 06:03 PM   #7
dsraven
ok, correct me if I am wrong and I don't mean to hurt anybody's feeling here, I am sure I missed something.
47-53 are the same truck basically. some differences in the door handles and side windows
54-55.1 are basically the same as the earlier trucks except they have a one piece windshield, so no more split. some differences in the front end parts body as well I think
55.2-57 are basically the same with single headlights each side
58-59 are basically the same as 55-57 except they have dual headlights each side plus a longer hood/fender/frame. the cabs are the same cab from 55.1-59 except for the GMC versions which have a totally different dash
47-55.1 are called advanced design thus the AD designation a lot of guys use
55.2-59 are called task force trucks thus the TF designation
if you go to the site below you may find all sorts of useable info for your truck
http://chevy.oldcarmanualproject.com...esto/index.htm
dsraven is online now   Reply With Quote
Old 09-24-2017, 06:10 PM   #8
mongocanfly
Post Whore
not short...no worry...just confusion...like Dan stated in post 4...1955 was a split year of body styles...commonly referred to as 1st and 2nd series...they go 47-55.1(the A.D. era) and 55.2-59 (the T.F. era)
sorry (I was off in internet world and the post didn't update until I replied here)..they covered it..
Old 09-24-2017, 07:48 PM   #9
Dan in Pasadena
Originally Posted by dsraven View Post
ok, correct me if I am wrong:
47-53 are the same truck basically. Some differences in the door handles and side windows...
Not sure of the dividing year for these changes but:
- Some have two piece windshields and later ones have one piece.
- Some have turn down door handles/some not.
- Some have wind wings/some not.
- Some have air vents on the side of the cab/some not.
The AD guys know the dividing years. I am a Task Force guy so I don't, sorry.
- Yes, but '55.2 has large centrally located hood ornament
- '56-'57 have hood ornament that is longer and mounted along leading edge.
- Side emblems on '55 have white background, is one piece & below belt line.
- '56 is two piece, has black background & is above belt line.
- '57 has a long oval side emblem above belt line.
- '57 has the "mouth" style grill which requires front fenders be slightly different.
- '57 hood has two raised ridges, '55.2 -'56 hoods are smooth.
58-59 are basically the same as 55-57 except they have dual headlights each side plus a longer hood/fender/frame. The cabs are the same cab from 55.1-59 except for the GMC versions which have a totally different dash
Yes, but '58-'59 hoods and hood hinges are different and not interchangeable. (Well, not easily! Lol). So where/how they bolt onto the cab is different. But it CAN be changed. Kabwe(Bam) has backdated his '58 to wear a '55.2-'56 front clip.
47-55.1 are called Advanced Design thus the AD designation a lot of guys use.
- Yes, BUT they start with '47.2. '47 is a split year as is '55. '41-'47.1 are Art Deco trucks; also abbreviated AD sometimes.
Hope this was helpful and not annoyingly detailed.
PS: I didn't notice if you were short. All's cool.
Old 09-24-2017, 10:53 PM   #10
Foot Stomper
Foot Stomper's Avatar
Hi guys
Cheers
Dale
55.2 to 59 had three hub cap clips and are 4.5 inches wide.
Previous to 55.2 they had 6 clips and were 4" wide.
A 16" three clip was offered in the Task Force and Blue Chip (GMC) series.
Yes, both will fit, but are not the same as described above.
So when is this "Old enough to know better" supposed to kick in?
My 1959 GMC build thread http://67-72chevytrucks.com/vboard/s...d.php?t=686989
Foot Stomper is offline   Reply With Quote
Old 09-26-2017, 04:47 AM   #11
doubledoyle
Cheers thanks for all your replies guys.
I'm from the uk and parts are hard to come by so this information really helps
