Old 09-24-2017, 08:26 PM   #1
forestb
forestb's Avatar
steering column squeaking
My original steering column is squeaking and I am wondering what kind of lubricant should I use to try to get rid of the squeaking. The bottom bushing is brass.
forestb is offline   Reply With Quote
Old 09-25-2017, 09:10 PM   #2
Lugnutz65
Lugnutz65's Avatar
Re: steering column squeaking
I'm guessing the squeak is heard loudest INSIDE the cab. Make sure your upper bearing is properly seated. I'd use white lithium spray on the upper bearing.
If the squeak is from the shifter, then maybe you'll need to disassemble things to find it.
Maybe you'll share the part number and vendor name who you got the lower column bushing from? Please.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 09-26-2017, 11:48 AM   #3
forestb
forestb's Avatar
I will take a look through my records. I was a few years ago when I bought the bushing.
Old 09-26-2017, 12:03 PM   #4
Lugnutz65
Lugnutz65's Avatar
Is THIS the correct lower column bushing? LINK
Old 09-26-2017, 12:27 PM   #5
forestb
forestb's Avatar
It is not where I ordered it from but it looks similar.
Old 09-26-2017, 07:36 PM   #6
rvrfoot
Check it out it could just be going out.
rvrfoot is offline   Reply With Quote
