Carrier bearing help
I have been looking through the threads and cannot find pictures for the carrier bearing for my 1960 longbed. I know there are 2 different types used and mine had the D shaped one, but it was clearly installed improperly and I think in the wrong placeas well. Does anyone have pictures of what their 60 longbed carrier bearing looks like and where it is installed. I have only seen pictures of the later trucks without the X frame.
The PO put cut a piece of steel that sat under the bearing mounts and slid it through the X frame. They then bent the edges of the carrier bearing around the piece of steel to hold it in place. I don't have pictures of the steel piece but, the carrier bearing how it was placed, clearly off center. If anyone knows where i am supposed to have it, any info would be appreciated. Thanks, Josh |
Re: Carrier bearing help
These are pictures of my 62 long bed.
Thank you clarsen. That's exactly what I needed to see. Now off to find the bracket I'm missing or have one made.
Thanks! |
The x frame kinda looks like my 61 impala. The holes are on the bottom plate.
