Post Whore
![]() Join Date: Feb 2000
My buddy has lowered his 65 Chevy and now the front brake lines are too short. What is the normal way to correct this. On 4x4's we normally splice in a longer piece of metal line and/or make a braket to lower the mounting point.
What is the best way to correct this problem?
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
Rockers1/2"off the ground
The steel line part or the rubber hose part is too short??
1962 fleetside: bodydropped,shaved,bagged,custom 64 suspension,clear taillights,custom aluminum parts,rollin on 100 spoke player wire wheels. http://www.finelinedesignz.ca |
Post Whore
I believe it is the rubber hose that is too short. I asked if a hose from a 67-72 4x4 would work, but he said they are too long and he is not sure what rubber hose he might use that would be longer than the 65's hose.
If he adds to the steel line, he can make a drop bracket so he could use the original rubber hose length. He just isn't sure what is the best solution.
