6 Cylinder Motor ID
I realize by looking at those cylinders its a boat anchor but is it a 235 boat anchor or 261 boat anchor? A buddy says its a 261, I'm betting on 235. Its in a '60 Apache.
Re: 6 Cylinder Motor ID
Holy buckets thats an in-your-face big picture. Need to find a way to resize....
Check The Champ, Demonstrator
![]() Join Date: Jun 2009
Met a guy at a truck meet 2 weeks ago and he was saying if there are two bumps above the starter on the block that is an indication of a 261. The 235 does not have the bumps apparently.
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
I resized it.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
![]() ![]() Join Date: Apr 2012
Measure the bore since the head is off , 235 3.5625 , 261 3.750
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
Check for the "captains bars" above the starter.
Nik...................____ 62 lwb c10 step-side 261 5 spd .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ my build thread. Sending unit solution |
![]() Join Date: May 2011
Yup, bore size will tell you, and the captains bars cast in the block above the starter. By your picture, it could be either.
1960 Chevy Apache10 Short Fleetside 1961 Chevy Apache10 Short Fleetside 1961 Chevy Apache20 Fleetside 1963 Chevy C10 Short Fleetside 1965 Chevy C10 Short Stepside 1965 Chevy C10 Long Fleetside 1966 GMC 1000 Long Fleetside 1966 Chevy C10 Short Fleetside |
By bore size its a 235. My buddy said there was a difference in placement of distributor and fuel between the two.
