Old 09-26-2017, 08:13 AM   #1
FatBak39
Help identifying front, 6 lug disk, brake setup
Working on a 69 C10 that has 6 lug front disk brakes and I need to ID this setup? I don't know if the previous owner sourced later model parts or if they are aftermarket. I need to replace the rotors, wheel brgs, calipers etc. I'm installing a power rack and pinion setup from CPP and refreshing all front braking components.
FatBak39 is offline   Reply With Quote
Old 09-26-2017, 11:22 AM   #2
hewittca
hewittca's Avatar
Re: Help identifying front, 6 lug disk, brake setup
I think if you can figure out what spindles you have, you're headed in the right direction.Are they drop or aftermarket spindles with any company info on them? If so, I would guess that they are from an aftermarket 6 lug kit designed to fit the balljoints/tierod ends of your truck. Otherwise, your balljoints/tierods would have had to be changed to fit a later model spindle/disk setup.
Builds: Green Gus the 68 C10 ; Sullii the 72 1500
Instagram: @dr.hewitt
C10 Concept/Development Photos: Master Thread
hewittca is offline   Reply With Quote
Old 09-26-2017, 11:27 AM   #3
54Caddy
GM Addicted
54Caddy's Avatar
Take rotor off. Some companies have the casting info on front of spindles.
..Mac’s Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is offline   Reply With Quote
Old 09-26-2017, 03:28 PM   #4
mikecaddy500
mikecaddy500's Avatar
They could be the stock rotors.
mikecaddy500 is offline   Reply With Quote
Old 09-26-2017, 10:13 PM   #5
FatBak39
OK, thanks for the replies guys. I pulled the rotors off and looks like they're McGaughys 2.5" drop spindles. Called them and they told me I could get all the parts at my local parts supplier, not. Finally just ordered an entire kit from Summitt.
