Old 09-26-2017, 08:22 PM   #1
SleepyK5
1949 4400 series truck
Anyone know how to get the rear drums off?
SleepyK5 is offline   Reply With Quote
Old 09-26-2017, 08:45 PM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: 1949 4400 series truck
https://www.stovebolt.com/ubbthreads...&Number=561303
Old 09-26-2017, 08:46 PM   #3
mongocanfly
Post Whore
http://vcca.org/forum/ubbthreads.php...ar_hub_assembl
Old 09-26-2017, 08:46 PM   #4
mongocanfly
Post Whore
http://chevy.oldcarmanualproject.com...51ctsm0501.htm
Old 09-26-2017, 09:01 PM   #5
SleepyK5
Thanks! It appears from the shop manual that the hub and drum are separate! Really confused me!
Old 09-26-2017, 09:14 PM   #6
paulspickupparts
Take the 5 bolts off the hub cover . There will be a large nut behind it . Remove that and pull the hub. Hope the drum is ok . If not you have to remove the studs to get it away from the hub. Good luck.
paulspickupparts is offline   Reply With Quote
Old 09-26-2017, 09:37 PM   #7
SleepyK5
Thanks that makes sense! Appreciate the help!
Old 10-08-2017, 03:03 PM   #8
SleepyK5
Electrical help!
1953 6400. Power to coil! Power to points. No spark at plugs!
New points, condensor, plugs, rotor and cap?
Old 10-08-2017, 03:35 PM   #9
mongocanfly
Post Whore
I had basically the same problem once....turned out to be the condensor...
be just as well to just change it all...points, condensor, rotor button, cap
Old 10-08-2017, 03:54 PM   #10
SleepyK5
I failed to mention i replaced the condensor as well?
QUOTE=mongocanfly;8056454]I had basically the same problem once....turned out to be the condensor...
be just as well to just change it all...points, condensor, rotor button, cap[/QUOTE]
Old 10-08-2017, 03:57 PM   #11
SleepyK5
I guess I wasn't clear. I put in New points, condensor, rotor and cap.
Also new plugs. I have power to the points. Checked coil it's ok.
I'm at a loss?
Old 10-08-2017, 06:12 PM   #12
dsraven
check the points, sometimes they short out or have goop on the contacts so they don't actually contact. try turning the dist shaft till the points are open,then, with key on, short the points across with a screw driver. it should spark then. check for spark with the coil wire that goes to the dist normally. I have had trouble with new condensors being no good as well.
Old 10-08-2017, 06:13 PM   #13
dsraven
on the brake drum, you may have to loosen off the brakes first to get the drum past the shows.
Old 10-09-2017, 11:47 AM   #14
Second Series
Second Series's Avatar
You can connect an ohm meter between the coil - and ground. disconnect the coil + first. Rotate the distributor to check for open/close on the ohm meter. You can crank the engine to get the points just open and have enough wiggle room to rotate the distributor by hand, or place the ohm meter where it is visible through the window to see it while you engage the starter. it should toggle 0v/ovl.
Second Series is offline   Reply With Quote
