Old 09-26-2017, 09:08 PM   #1
Steelydan
Steelydan's Avatar
Frame restoration bolts
Hey everyone I’m in the process of getting ready to start reattaching my crossmember to the frame and many other parts. What has eveyone use for bolts to do this? Thanks in advance
Steelydan is offline   Reply With Quote
Old 09-26-2017, 09:16 PM   #2
Mr Handy
Mr Handy's Avatar
Re: Frame restoration bolts
Any time I removed rivets from the frame I replaced them with grade 8 hardware.
I am also fond of serrated flange nuts for this kind of stuff.
Mr Handy is offline   Reply With Quote
Old 09-26-2017, 09:18 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
Grade 8 bolts and hardware, and make sure they fit in the holes snug. I drill all of mine out so 7/16 bolts fit snug.....
LockDoc
Leon
Old 09-26-2017, 09:21 PM   #4
crakarjax
crakarjax's Avatar
+1 to grade 8, I use flat washers on each side to save my paint and prevent rust and also use red loctite -- NO lock washers. Prime and paint over the bolts and washers afterwards.
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
Old 09-27-2017, 01:18 AM   #5
kwmech
I agree, no lock washers. I use the pinch type self locking and fine thread bolts. Torque 'em to 70lbs
Old 09-27-2017, 12:08 PM   #6
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Subject recently came up someone's undercarriage had the wrong bolt finish (i.e., some hardware was not phosphate coated).
From what I see, you don't have much choice in the matter. Take the axle plates for example. They're (GR 8) 9/16" hex bolts, lock washers and nuts. The bolt threads are 3/8-24 x 1.
Unless you can locate NOS, where are you going to find that in anything other than stainless or yellow zinc? I suppose you could attack the zinc and have them coated. I'm on-board with the factory look & parts, and that's my goal, but if you ask me, yellow zinc works.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 09-27-2017, 12:41 PM   #7
beaterku
beaterku's Avatar
You can get black phosphate bolts from Mcmaster.
beaterku is offline   Reply With Quote
Old 09-28-2017, 12:38 AM   #8
Steelydan
Steelydan's Avatar
Thank you everyone for the replies I am wanting to keep the truck as close to original as I can.
Old 09-28-2017, 08:20 AM   #9
indymachinist
I buy a lot of "truck part" hardware from mcmaster. But I'm not afraid of yellow zinc hardware on mine.
-Curt
My 1968 Chevy shortbed stepside build
indymachinist is offline   Reply With Quote
Old 09-28-2017, 10:31 AM   #10
B. W.
B. W.'s Avatar
I used hex head flange bolts (also called frame bolts) on my crossmembers. Also did what LocDoc said: drill out to 7/16" where possible. The holes were so wallowed out on my engine crossmember (old 4x4 farm truck) I had to weld up the holes & re-drill to 3/8" because I had clearance issues with 7/16".
I've taken yellow zinc hardware, bead blasted it then re-finished in a black phosphate home brew. It comes out out looking good but is a lot of work. Add to that, I think the zinc coating provides better protection.
I use McMaster a lot also.
B. W. is offline   Reply With Quote
Old 09-29-2017, 12:59 AM   #11
Spf79
Spf79's Avatar
I went with stainless grade 8 bolts and lock nuts.
Full top blazer or bust....
Spf79 is offline   Reply With Quote
Old 09-29-2017, 01:20 AM   #12
crakarjax
crakarjax's Avatar
I hope those are ARP because afaik they are the only manufacturer of stainless that is as strong as grade 8
Old 09-29-2017, 01:47 AM   #13
Spf79
Spf79's Avatar
I got them from a bolt supply house I deal with through work. I sell a lot of bolts, mostly large diameter flange kits for piping, so my knowlege is limited. I appreciate the heads up, I will look into this, better safe than sorry.
Have a good night!
Old 09-30-2017, 09:45 AM   #14
Steelydan
Steelydan's Avatar
Looks great where did you find 7/16 black phosphate nuts at.....? I am having trouble finding that size of nut in the black phosphate?
Old 09-30-2017, 11:34 AM   #15
71CHEVYSHORTBED402
Anyone ever use black oxide stainless steel? Has a nice look. McMaster_Carr carries black oxide stainless steel 18-8 nuts. Can't say if they're automotive quality.
Black phosphate replacement nuts and washers would be great, but I'm missing them. That's partially because can't make out what "18-8", and "18-10" nuts are. Seems to me you want an equal nut and washer for a Grade 8 bolt. In other terms, how does 18-8, 18-10 or other suit a Grade 8 bolt? Grade 5 as well.
I believe original hardware is manganese phosphate. Here's a website that explains the difference between that and zinc phosphate. Judging by the photo, I'd say the nuts are zinc phosphate, and beautiful finish. IMO it's superior in appearance. Likely more corrosive resistant too. Might bring a bit too much shine to under the hood, but would make for a beautiful under-carriage, IMO http://imf-co.com/portfolio/phosphat...houston-texas/
Tony
Old 09-30-2017, 11:49 AM   #16
indymachinist
18-8 and 18-10 is the amount of chromium and nickel the stainless has in it. It's not a grade like 5, 8, etc.
-Curt
Old 09-30-2017, 11:58 AM   #17
71CHEVYSHORTBED402
Understood, but how do they match up to Grade 5 & 8?
If you go to the hardware store, they have "grade 8" nuts and washers for grade 8 bolts. The same doesn't seem to apply for grade 5 bolts. I suppose that means standard nuts and washers work for grade 2 and grade 5 bolts.
Tony
Old 09-30-2017, 07:13 PM   #18
crakarjax
crakarjax's Avatar
My store has grade 5 and 8 nuts, and you can get matching washers but the strength on those isn't critical. 18-8 is weaker than grade 5.
Old 09-30-2017, 07:23 PM   #19
mike16
I think the best they can do in terms of strength is a little bit more than grade 5.
There are vendors who deal with the NCRS crowd that actually sell the factory rivets, you have to heat them up and install them yourself .
mike16 is offline   Reply With Quote
Old 09-30-2017, 09:28 PM   #20
indymachinist
When looking at bolts on mcmaster.com compare tensile strength of the bolts like grade it said 150000 and 18-8 said 70000
-Curt
Old 09-30-2017, 10:13 PM   #21
B. W.
B. W.'s Avatar
I believe I bought them here:
https://www.nutty.com/Grade-8-Hex-Fl...uts_c_367.html
Old 10-04-2017, 11:20 PM   #22
Steelydan
Steelydan's Avatar
Thanks for all the great replies I think I have it all figured out what I’m going to use once everything gets back from being powder coated. Does anyone happen to know the size of the bolt for the Panhard bar to the frame. I misplaced the original one and would like to order all my bolts at one time rather than separate orders. Thanks in advance
Old 10-07-2017, 10:36 AM   #23
volksworld
an actual grade 5 nut will have 3 little depressions on the face like the 3 lines on the head of the bolt...find a better hardware store....
1970 short step c10 leaf spring 454
volksworld is offline   Reply With Quote
