Old 09-26-2017, 10:43 PM   #1
brizzle86
brizzle86's Avatar
Gauge pics
Im wanting to install Dolphin gauges that look stock in my truck.
Thats the easy part.
I also have 3 gauge cluster mounted bottom center dash.
Tach on floor.
I want trans temp, fuel pressure, air/fuel, oil temp,
Also keep engine and oil pressure even though stock cluster will have these two.
Do you all have any pics of your aftermarket gauges?
Do you all know of cluster that holds 6 gauges? Do i need to make one?
Are all these gauges over kill? Cruiser truck. I just like to be able to monitor.
I attempted to add attachment pic but pic would not upload.
Ill try again later when im on laptop instead of phone.
1947 Chevrolet 3100 3 window, 81 camaro clip, ls2, 4l60
brizzle86 is offline   Reply With Quote
Old 09-29-2017, 07:50 AM   #2
Jemezcrusher
Re: Gauge pics
I thought about the Dolphin gauges until I read reviews on this forum and other sites. Decided. Iwill likely go with New Vintage. Twice as much money but better reviews
Jemezcrusher is offline   Reply With Quote
Old 09-29-2017, 06:39 PM   #3
Black_Sheep
Black_Sheep's Avatar
Re: Gauge pics
Could you use something like this?
http://www.speedhut.com/customizer.i?clid=6729461
Black_Sheep is offline   Reply With Quote
Old 09-29-2017, 11:52 PM   #4
my56chevytruck
my56chevytruck's Avatar
Re: Gauge pics
Tach on floor.
The reviews of Dolphin gauges aren't complimentary, Check out the gauges from Auto Meter. I love em for my 56.
RUBBER DOWN AND HIT THE ROAD!!!
1940 Ford Dlx Coupe
1969 Mach1
my56chevytruck is offline   Reply With Quote
Old 10-01-2017, 09:58 AM   #5
Kansas T
Re: Gauge pics
I used Dolphin gauges in a 48 that I built a few years ago. I won't be using them for my 52 build. The speedometer setup never worked correctly, but I did end up getting it to read close to the correct speed. The back lighting was also different between the two gauges. One was much brighter than the other.
Kansas T is offline   Reply With Quote
Old 10-01-2017, 04:22 PM   #6
crossfire84
crossfire84's Avatar
Re: Gauge pics
Go with Dakota digital.
LIL ERV the 50-3600
396 BBC stroked to 415 cid
Richmond 6spd over drive
C4 rear
Porter built a arms
Never give the Devil a ride,because he'll want to Drive!
crossfire84 is offline   Reply With Quote
Old 10-01-2017, 04:41 PM   #7
my56chevytruck
Re: Gauge pics
Here's the Auto Meter gauges I'm using with the black needles
https://www.boeseengineering.com/ima...3003AW_700.jpg
1940 Ford Dlx Coupe
1969 Mach1
Old 10-01-2017, 09:56 PM   #8
Black_Sheep
Re: Gauge pics
I made this for the '58
