Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 09-26-2017, 11:29 PM   #1
1960chevypanel
WTB: 1960-1962 automatic radiator
Looking for a 60-62 radiator with the trans cooler lines at the bottom. Please post or PM with leads.
1960chevypanel is offline   Reply With Quote
Old 09-27-2017, 09:18 AM   #2
ratskin
Re: WTB: 1960-1962 automatic radiator
If you're not worried about numbers correct, you can find an aluminum one for $200 or less. More fore brass.
ratskin is offline   Reply With Quote
Old 09-27-2017, 11:24 PM   #3
1960chevypanel
Would like to find an OEM one. Where have you shopped for aftermarket?
Old 09-28-2017, 12:30 AM   #4
Hmh70
I have a fan shroud for a v8 auto. I think I might have sold radiator
Hmh70 is offline   Reply With Quote
Old 09-28-2017, 07:45 AM   #5
ratskin
Bought the one for my 64 at Advance. Aluminum. fit perfectly.
Old 09-29-2017, 10:23 AM   #6
runningiron
runningiron's Avatar
I have one that came out of a 1962 C-10. It is a Harrison 3145865 R-65 61 J. The core measures 23 1/2" X 20" X 3". It looks to be in good shape overall, and would be worth restoring. I'll take take $50 plus shipping from Arizona 85123 which is in between Tucson and Phoenix, Az.
runningiron is offline   Reply With Quote
Old 09-29-2017, 11:04 AM   #7
runningiron
I also have the metal fan shroud that came off the same truck that had a 283 and auto trans. It is in excellent condition, not cut up, not rusty, just minor surface rust, all mounting screws there. $150 plus shipping from Arizona 85123.
Old 09-29-2017, 12:31 PM   #8
chtr65
That is a hard to find pair here in my neck of the woods. Thats only the second time I've seen one of those original V8 shrouds. I had a 62 1/2 ton with 283 power glide transmission. It came with the metal shroud but it was trimmed back on the engine side. So I guess I should say this is the first one in nice uncut shape that I have seen. Hope it finds the correct truck to match up to.
chtr65 is offline   Reply With Quote
Old 09-29-2017, 12:58 PM   #9
runningiron
Yes Sir, I hope someone could use this cherry shroud.
Old 09-29-2017, 10:57 PM   #10
Brad54
Brad54's Avatar
Wow, that'a a nice combination right there. And the price is very good.
I bought a good aftermarket radiator that looks stock (but without the numbers/name), and was happy with it... from Be Cool, I think. But it didn't come with the mounting tabs for the fan shroud.
For the price, that'd probably be worth having recored or repaired.
Just for giggles, send me a PM with what the total would be with shipping to zip code 30549.
I don't NEED need it, but I've got a '61 Suburban I need to get back on the road, and it needs a new radiator and shroud (killed by a deer), and I've got a '62 K10 I'm going to start on in the spring.
-Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
Old 09-30-2017, 09:10 AM   #11
60-66
60-66's Avatar
Brad , thats an automatic fan shroud. The Manual Transmission shroud is different , different mounting , unless your going automatic in your K series truck ?
https://67-72chevytrucks.com/vboard/...1966+gmc+panel
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 09-30-2017, 09:52 AM   #12
Brad54
Brad54's Avatar
The automatic radiator and the 1-ton radiator (and maybe 3/4-ton) are larger than the 1/2-ton manual trans radiator. They're a little wider, and a little taller: they make up the difference in the mounting flange: they'll still bolt into the 1/2-ton core support.
The automatic shroud also covers the entire radiator core, the manual trans shroud is just a barrel, so it doesn't pull air through the edges or corners.
So that's a better package for cooling than the stock 1/2-ton stuff. Nice for Atlanta, really nice for low rpm driving through woods and trails.
Old 09-30-2017, 10:19 AM   #13
60-66
60-66's Avatar
Good points !
Old 09-30-2017, 12:05 PM   #14
1960chevypanel
Just what I'm looking for, thanks. I'll take both pieces, please PM me with payment info. I might be able to get them picked up.
Old 09-30-2017, 01:30 PM   #15
runningiron
Both radiator and shroud sold to 1960chevypanel pending payment.
Old 09-30-2017, 01:34 PM   #16
runningiron
Brad54, I gave 1960chevypanel an opportunity to buy both pieces in response to his wanted to buy posting. If he backs out, I will send you a quote for shipping and an opportunity to be second inline. Thanks Runningiron.
Old 09-30-2017, 06:38 PM   #17
runningiron
Radiator and shroud sold to 1960chevypanel
Old 10-01-2017, 11:18 AM   #18
Brad54
Brad54's Avatar
Oh, I COMPLETELY understand! No hard feelings whatsoever. I forgot to add "if the deal falls through" when I asked for a zip quote.
Good pieces--he'll make good use of them!
-Brad
Old 10-01-2017, 12:20 PM   #19
runningiron
Brad54, Thanks for your understanding, it is much appreciated, Sir.
