autometer speedo problem
I recently put an autometer speedo in my truck and it seems off.
When I'm rolling along 5 - 10 mph the needle is still sittitng on the 0 mark. And then driving at around it seems 5 mph slow (so I'm going 5 mph too fast) Anyone else with this problem? Should I call Autometer? My factory speedo was about 3% fast before I switched to this one (due to smaller tires). |
68cst_ss490
is it a cable driven speedo or a electric one. maybe u could change the gear in the trans and it will correct it for u
Dean edmonton,canada a winter wonderland 2005 Chevrolet Avalanche LT cold air intake, performance exhaust, Comp cams cam, jba shorty ceramic headers. http://www.cardomain.com/ride/3090973 |
It is a cable drive, and it's not a gear thing. It's just off set 5 mph at all points.
FORSALE
the auto-meter phantom i have was calibrated at 2000rpm's it reads 60mph. that is 2000 rotations of the speedo cable itself.
i just took the truck to a garage and they put new speedo gears in the tranny. to many numbers to take into consideration for me like final tranny ratio, rear end ratio, tire size...
1967 chevy 1/2 ton short step |
68cst_ss490
if it is out by 5 mph throughout the whole range it sounds like the driven gear is wrong to me....
it worked fine with the factory speedo. I think I'll give autometer a call
