I am looking for item number 15 in bulk. The Holley ones are paper and good for a couple tightens. I need a correct part number, heard they come in a nylon 10 pack. Some said 510-1008-777 was the correct number. Not certain. I think maybe Midwest fasteners has some in the parts bin or perhaps fastenall or another source. The Carburetor is a 750 #4150.
Thanks in advance! Hubcaplarry ![]() |
It's Better With Nitro
Re: Source for carb part
I used to use the teflon needle seat adjuster nut washers. You can do a search for the teflon washers. I think BLP still sells them in packets and individually.
thanks vin63...ended up at Lowes in the hardware drawer. Nice fit and price.
upper washer https://www.lowes.com/pd/Hillman-2-C...Washer/3013072 lower washer https://www.lowes.com/pd/Hillman-5-C...ashers/4635727 $4.00 for several packs! Hubcaplarry |
Wow lowes had everything.
