09-28-2017, 01:54 PM | #1 |
tilt wheel shift selector bulb replacement
Help please.
Mine is a 72 Chevy Cheyenne C20 that I'm trying to replace the shift selector bulb on. I've removed the shift selector to get at the bulb location but find a metal protrusion above where the bulb goes in which prevents insertion of the bulb (see photos). I've seen an old thread showing great pictures but the metal thingy isn't in those pictures. I don't see that it performs any particular function. Does anyone know what it is, why its there and/or otherwise how to replace the bulb? Can I remove it without some problem? Also, according to the old pictures, I'm missing the bullet shaped metal bulb cover and the green cap. A question was posed in the old thread about where one might find those items but received no answer. Anyone out there have an answer now? Thanks. |
09-28-2017, 05:34 PM | #2 | |
Re: tilt wheel shift selector bulb replacement
Below is a picture showing the parts that are above the light socket. The steel cap needs to be removed to change the bulb. It just lifts off. The purpose of the cap with the slot is to direct the light toward the shift indicator. Obviously, the green filter is to match the greenish lighting from the instrument cluster. I'm not sure where to get the pieces you have missing, but there are a few members here who restore these columns and could possibly help. Two who come to mind are 70shortfleet and KevsClassics. Last edited by FirstOwner69; 09-28-2017 at 10:53 PM. |
09-28-2017, 08:57 PM | #3 |
It holds the teeth part of the tilt in place. It should be pushed in flush with the metal. Not sure why it isn't. You could go ahead and tap it in flush but myself I would remove the top sleeve to see why it is out.
09-29-2017, 03:26 PM | #4 |
Thanks for the help guys. Explains what's going on.
