09-28-2017, 07:29 PM | #1 |
Vinegar at work.
I'll try and take some pics tomorrow.....my method is really "jerry rigged."
I decided to let the cable ends soak overnight in the vinegar. Hopefully that will make them shiny and get me through a couple of starts this fall. |
09-28-2017, 09:17 PM | #2 |
Re: Vinegar at work.
If you've got the length, try cutting back an inch or two to get clean copper, unless you have fixed-lug terminals.
09-29-2017, 03:14 AM | #3 |
That's not a bad idea. I'm letting it soak overnight to see what the effect is....if it's good I may take your advice.
And the more I think about it (and watch youtube videos) the more I want to go on and make my own cables as it's been suggested many times here. |
09-29-2017, 02:59 PM | #4 |
Ugh....tension in negative caused the cable to come out of the soak. I may go on and make new cables.
09-29-2017, 08:42 PM | #5 |
If you want the copper to shine like new it is lemon juice and salt that you soak them in and you should see results in minutes
09-30-2017, 06:42 PM | #6 |
Born Psycho
wait a dadgum minute here- i "jerry" rig everything i do.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
10-01-2017, 12:55 AM | #7 |
10-01-2017, 09:51 AM | #8 |
I've tried both and they both left a weird after taste and upset my stomach. I'd leave the battery cables out for best results
10-02-2017, 12:29 AM | #9 |
