![]() Join Date: Mar 2013
Identifying Carbs
Can anyone show some light on identifying the correct year and model of carbs for our trucks by the number codes? I'm trying to find the correct carb for my 1965 1/2 ton 283 with powerglide transmission. What make carb would have come on my truck? Thanks in advance.
Re: Identifying Carbs
And it had a power glide trans
![]() Join Date: May 2011
Original carb would have been a Rochester 2GC. Used on all 2 barrel 283's.
1960 Chevy Apache10 Short Fleetside 1961 Chevy Apache10 Short Fleetside 1961 Chevy Apache20 Fleetside 1963 Chevy C10 Short Fleetside 1965 Chevy C10 Short Stepside 1965 Chevy C10 Long Fleetside 1966 GMC 1000 Long Fleetside 1966 Chevy C10 Short Fleetside |
![]() ![]() Join Date: Apr 2012
Look for a metal tag hanging off the front. Will have the part number and date on it. Many times when these were rebuilt over the years the tag was removed
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
Thanks for replying and the good info. I was thinking it would have been a 4 barrel carb. Looks like not so.
No 283 4 barrels in C10’s, only 2 barrels
Posted via Mobile Device |
Stock 2 bbl intake would be part ( casting number) 3840905 stock Rochester 2 bbl carb number would be 7024101 for standard trans and part number 7024110 for automatic trans.
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
I was given the original intake by PO. Now I can check the casting number to verify. Thank You, Good Info.
Is the intake 2 or 4?
Took a look at the intake that the previous owner handed to me, that was on the motor when he purchased the truck. Was painted grey. Casting number is 3905398. And a 4 barrel intake. So I took a knife and scraped the paint, and there is original orange paint underneath the grey. Looks like I've been holding on to an intake that is doing me no good. Glad I ask here on the forum. Not sure what it's from. Anybody know?
If that last digit is a 3 instead of an 8 than according to nastyz28 website it is from a 66-68 327 with a quadrajet.
Mark ![]() '63 C10 short step |
#13 |
Thanks for correcting the number. It is 3905393. Do appreciate your help. Now I need to find the correct intake. Many Thanks
#14 |
if your not worrying about date codes and we were not so far apart. I have a complete setup intake carb air cleaner from a 64 chevelle 283 pg with 54 K miles. was removed to install 4 barrel.
so they are out there.good luck |
