Old 09-29-2017, 07:09 AM   #1
Hazieview
Building Dreams out of Dimes!
Turn Signal Switch Replacement. Help with wires through column.
I've used the search feature but I cannot find anything related specifically to the 1973-87 turn signal switch replacement. Specifically how to run the wires through the steering column. I was just thinking about cutting and splicing the wires or installing a plug in case I have to change the turn signal switch again. Any ideas on an easier way to remove and reinstall the turn signal wiring back through the steering column? Any help would be greatly appreciated.
(I gave all the proper tools including the compression tool. Any other advised maintenance to consider would be greatly appreciated also. )
Thank y'all!
1981 Chevy short/wide.
SB400 350th
Hazieview is offline   Reply With Quote
