Building an engine
Hi folks:good afternoon.
Firstable, thank you so much for help me to understand how to upload photos, finally looks that I can do it. Ok: last december I bought an engine with the idea of look for someone to help me rebuild it. Finally is here. So far was assembly with Forjed flat pistons. Crower Baja Beast Hidraulic Cam. And this heads. to continue, I would like to know what would be the correct intake perfect for this engine. now I have installed an intake like this in the engine of my truck but I don't know if this will work good? thank you so much for all of your help, |
Active Member
![]() Join Date: Feb 2016
Re: Building an engine
I would use the edelbrock rpm intake. Hard to tell without more info, like what your trying to achieve ( towing, street/drag, ect...). But I think the RPM is a good all around intake.
So the truck has a 305 now and your replacing the engine?
If so what block are you installing. If your rebuilding the old 305 personally I wouldn't bother. 305s are dogs and not worth putting that kind of cash into. It just won't get near the performance as a 350 with similar upgrades. |
#6 | |
Posted via Mobile Device |
Hi folks good morning.
The water neck on the edelbrock intake leaks water coolant. I’ve been trying to stop the leak with different gaskets and still leaking, but I’m not sure if besides the gasket it also needs an o ring or if there is an special gasket. Thank you |
You can buy o-ring type gaskets.
No gaurentee you'll stop the leak. Sometimes it's a better idea to get a better thermo housing. http://www.autozone.com/cooling-heat...41_69327_15298 |
#11 | |
#13 |
All about them K’s
![]() Join Date: Jun 2014
A little Permatex the right stuff gasket maker on both sides of the gasket and it won’t leak. Doesn’t take much. Those thermostat housings can be fun to get to seal.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
#14 |
Hi folks good afternoon: from San Diego I wish you a HAPPY THANKSGIVING!!!
Enjoy your Dinner!!! I need your help. I bought this air filter at a car show but now I can't find the replacement. long 14 1\2 in wide 8 1/4 in thick 2 in thanks for you help |
#15 |
Here is the air filter container
#16 |
The Older Generation
Not sure if this will work or not.... https://www.oreillyauto.com/detail/k.../e3515/4394052 Or maybe this one.... https://www.speedwaymotors.com/Singl...ment,4472.html LockDoc
#17 |
#18 |
#19 |
#20 |
No problem. Post up which one works for you if you have time. LockDoc
#21 | |
#22 |
