09-29-2017, 09:02 PM | #1 |
Junior Member
Plug wires for HEI and stock exhaust
I've got a GM Goodwrench 350 with HEI and stock exhaust manifolds. I pulled the plug wires off a while ago and just got around to installing new ones. For some reason, I had purchased these, which do not appear to be correct for my truck. There's at least one wire that's way too short. I did some searching it sounds like Taylor is pretty popular. I believe this is the correct set ('71 C10 Suburban). I also cut the wire loom brackets off of the valve covers, so I need another loom solution. I saw that GMCPauls offers some, but I was wondering which one(s) I would need. There are rear, side and oil pan mounted retainers. Also wondering if I need the heat shields.
Thanks! |
09-29-2017, 09:15 PM | #2 |
Re: Plug wires for HEI and stock exhaust
I picked up a set of Accel universal wires for mine. Running stock maniforlds. But I got the ones with the straight boots. I think they may have been the 4040's.
Smitty '71 Short Fleetside Spring Valley, Ca. |
09-29-2017, 09:19 PM | #3 |
If you have the rams horns then just get a set of '75 Corvette stock replacement wires. They will be for the same style manifold and for an HEI. Typically you can get a pretty good set at RockAuto cheap. Right now the cheapest set they have is $12 and the Standard Blue Streak 8.5mm performance wires are $35.
The Denso 6718024 are spiral wrapped silicon 8mm wires and are $22 is what I think I'd spend my money on.
44 Willys MB 52 M38A1 64 Corvette Coupe 68 Camaro 'vert LT1 & TH700 69 Z/28 355 12.6's @110 69 Chevy Short Step 4 1/2"/7" drop 72 Jimmy 4WD 4spd 4" & 35's 02 GMC 2500HD 4x4 Duramax Last edited by Mike C; 09-29-2017 at 09:23 PM. Reason: added Denso part |
10-01-2017, 03:23 AM | #4 |
A/c delco vette wires, custom looms
I BELIEVE IN JOHN 3:16 |
