10-28-2003, 01:36 PM | #1 |
Clear coat remover for rims
Like the title says. What is a good way to remove the old clearcoat on aluminum rims? TIA, DK
10-28-2003, 01:40 PM | #2 |
Keepin an eye out
I asked the same question not long ago. Use Aircraft Paint Stripper from Kragen or Autozone. You may have do do it a few times but it doesnt hurt the finish.
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 |
10-28-2003, 01:54 PM | #4 |
Keepin an eye out
I think it was 7.50 for a 18oz. spray can and 20.00 for a gallon. I bought the gallon and used it on polished Centerlines and it pretty much bubbled the clear coat off with some spots I did have to reapply.
10-28-2003, 02:02 PM | #5 |
After I remove the clearcoat what should I use to shine up the brushed aluminum underneath(no theyre not chrome)... Would some chrome polish work?
10-28-2003, 02:13 PM | #6 |
Keepin an eye out
I woud check the parts store for some spray on aluminum cleaner for brushed finishes, look for Eagle One if you can find it.
10-28-2003, 03:29 PM | #8 |
1FINE69
Try Extreme polish, it looks like pink cotton wadding in a black plastic can. I have heard that and a dremel or small drill with a polishing bit does a great and quik job on aluminum wheels. The ones I saw done were as shiny as chrome wheels only took him 1/2 hour each wheel.
p.s put the unused wadding in a sealed bag to keep it from drying up.
Had a 69 swb fleetside 350zz3 w 400turbo trans oak lined bed with rhino coated sides red exterior. SOLD |
10-28-2003, 03:58 PM | #9 |
Keep On Truckin'
Just Passin' Thru Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire..... |
10-28-2003, 06:04 PM | #10 |
71 DELUX
be careful
Not sure what type of wheels you are working on.
Last year I saw a set of 80's Monte Carlo rims polished out like you occasionally see IROC rims polished. They looked KILLER. So I bought some for my S10 Blazer. I've had good success polishing motorcycle parts and wheels in the past. I did the whole paint stripping routine and cleaning, then moved on to my usual polishing process with attachments to my drill and compounds, but it did not work out very well at all. I can say with honesty that I'd NEVER try it again. Those aluminum wheels were too porous and simply did not take to the polishing process very well. It was a good learning experience that I'd never choose to experience again! I'm with ya though, and I love any gleaming polished aluminum wheels.
5/4 drop LWB wood bed - 15x8 front 235/60 - 15x10 rear 295/50 2003 FORD Escape 1998 Honda VTR1000 |
