Old 10-01-2017, 11:11 AM   #1
3 4EVER
3 4EVER's Avatar
Just had new camshaft installed
Well I just had a new camshaft installed on my 1972 GMC. What a difference it has made. Like driving a whole new truck.
1972 GMC Super Custom Highlander
3 4EVER is offline   Reply With Quote
Old 10-01-2017, 11:18 AM   #2
B. W.
B. W.'s Avatar
Re: Just had new camshaft installed
So.... what cam did you install?
B. W. is offline   Reply With Quote
Old 10-03-2017, 09:28 PM   #3
rockyrivermark
Yes. More info. What cam. What engine. Any other improvements on the engine
I'm looking to do this over the winter wth new heads also
rockyrivermark is offline   Reply With Quote
Old 10-03-2017, 11:04 PM   #4
Husker
Husker's Avatar
Subbed
Ron
Member #111
68 C-10 Daily Driver
70 4x4 Project
76 Jeep CJ-5
Help Support the Board:
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors.
Thomas Jefferson
Husker is offline   Reply With Quote
Old 10-04-2017, 09:48 AM   #5
3 4EVER
3 4EVER's Avatar
Sorry guys, not Mike the Mechanic here. Had everything done at my local shop. Here is a list of what was done to the truck. Truck also has a 350 with 91000 miles on it. Fuel pump gasket, hydraulic camshaft, manifold said, Lifter, timing chain set, timing cover set, valve cover gaskets, choke thermostat, PCV valve.
Old 10-04-2017, 10:30 AM   #6
berch 69GMC
berch 69GMC's Avatar
So what felt new? More torque, HP, sound, response?
berch 69GMC is offline   Reply With Quote
Old 10-04-2017, 10:48 AM   #7
3 4EVER
3 4EVER's Avatar
For starters, the truck doesn't feel like it wants to die every time you sitting at a red light. I always had to put it in neutral when I was in that situation. That is the biggest change that I have noticed so far.
