Old 10-01-2017, 05:00 PM   #1
richards72chevy
richards72chevy's Avatar
Do I need adjustment holes in my brake drums?
I just bought rear brake drums for my 66.They don't have the holes in them to make the adjustment.Do I need them since this system is self.adjustment?
richards72chevy is offline   Reply With Quote
Old 10-01-2017, 05:03 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Do I need adjustment holes in my brake drums?
Take a look at your backing plates.
Old 10-01-2017, 05:55 PM   #3
richards72chevy
Are you talking about the plate that the wheel cylinder mounts to?
Old 10-01-2017, 05:59 PM   #4
The Rocknrod
Moderator
Yes. Thats where the hole is. It's oblong, on the bottom.
The drums go round and round on the outside, attached to the axle.
The adjustment is made from the backing plate side, sometimes there will be a rubber plug installed if your lucky. Check this vid out at about the 3:30 mark -
https://www.bing.com/videos/search?q...37&FORM=VRDGAR
Old 10-01-2017, 07:41 PM   #5
richards72chevy
No holes there either.I thought about drilling a few holes in the new but I don't if the new drums are balanced.
Old 10-01-2017, 08:14 PM   #6
The Rocknrod
Moderator
Re View the video please. Do Not Drill the Drums!
The adjustments are made as the video shows, Not through the drums.
Your on the internet - Post some pictures for us please.
Old 10-01-2017, 10:40 PM   #7
geezer#99
geezer#99's Avatar
Don't drill the drums, drill and make a slot for the plug in the backing plate. Plugs can be found in the help section of your local parts store.
You need to adjust the shoes when first installed and then let the self adjusters fine tune them. You also need the plug/hole to maybe back off the brake pads if you need to remove the drums sometime in the future.
geezer#99 is online now   Reply With Quote
Old 10-01-2017, 11:58 PM   #8
Brad54
Brad54's Avatar
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
Old 10-02-2017, 01:01 AM   #9
luvbowties
luvbowties's Avatar
Thumbs up Re: Do I need adjustment holes in my brake drums?
See #19: http://67-72chevytrucks.com/vboard/s...d.php?t=628322 Hole in Drum.
See Hole in Backing Plate: https://www.google.com/search?q=rear...=1506920130931
luvbowties is offline   Reply With Quote
Old 10-03-2017, 08:34 PM   #10
racecougar
racecougar's Avatar
As shown in the link luvbowties posted above, the replacement JB5 Raybestos drums I purchased featured knockouts. The JB5 backing plates sourced from a later 12-bolt did not. Adjusting through the drums works just fine.
Rod @ AzzKicker Cars
1965 C10 SWB - Build Thread
racecougar is offline   Reply With Quote
Old 10-08-2017, 03:59 PM   #11
richards72chevy
Thanks for all of the response.Looks like I will be putting a hole on that plate
Instead of the drums.Thanks you guys
