1960 C10 LS Swap Questions
I'm looking to pick up a 1960 roller and throwing an ls into it. From my research, it looks like there's no kits for the 60-62 cars due to the torsion bars and x frame??
Would a front end swap make it so the 64+ ls swap kits would work? Or is there an easy way to get an ls into a 1960? If anyone has any info on this please let me know! Thanks! |
Re: 1960 C10 LS Swap Questions
Try looking in the search.
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
I would want disc brakes before I added power!
There are some... probably more 62's for some reason but they should be sane.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
http://67-72chevytrucks.com/vboard/s...d.php?t=694256
http://67-72chevytrucks.com/vboard/s...d.php?t=661818
hello look up 1960ape in the builds section he did a ls with 4l80e and kept torsion bars. I my self updated to a 73-87 front suspension... good luck with your project.
But Found Her 25yrs Later!
There are a couple build threads I came across recently, but I don't remember who they were. The two I read said they didn't have a problem with keeping the torsion bars. I think someone said something about using Camaro exhaust manifolds.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
The Camaro or TBSS manifolds fit tighter than any other .
![]() Join Date: May 2011
The 63-66 kits will work, just need a spacer , 1/2 inch, on top of the frame rail. No problem with the torsion bars.
1960 Chevy Apache10 Short Fleetside 1961 Chevy Apache10 Short Fleetside 1961 Chevy Apache20 Fleetside 1963 Chevy C10 Short Fleetside 1965 Chevy C10 Short Stepside 1965 Chevy C10 Long Fleetside 1966 GMC 1000 Long Fleetside 1966 Chevy C10 Short Fleetside |
Interesting information here. I ended up picking up the truck last night and the more I think about it, the more I want to keep the torsion bars. So would this swap kit get the motor into there?
http://www.ebay.com/itm/63-67-Chevy-...tY5S32&vxp=mtr and will these headers clear? they're the cheapest I've found. http://www.ebay.com/itm/Chevy-LS1-LS...xUd9qP&vxp=mtr |
The kit says 63 67. You have a 60?
Yep, I have a 60 but above, oldusa says that the 63-67 kit fits with a 1/2 spacer. Can anyone confirm?
#13 |
#14 |
Those motor mounts will work, with a spacer on the top frame rail. The trans crossmember will need to be shortened, 60-62 frames are narrower than 63-66 frames. The headers I don’t know, I used factory exhaust manifolds.
Posted via Mobile Device |
#15 |
I used some ebay weld in motor mounts in my 62 and made them bolt in for my 4.8 swap. Also made my own trans mount to fit between the x frame. Still running t-bars on drop spindles with disk brake. Used speed engineering shorty swap c10 headers with x pipe tucked into the t-bar cross member.
| Bookmarks |
