No Instrument Lights, Turn Signals, Radio
After getting the engine in running order, been moving on to interior. It's in really good shape, no rips on the seat, dash is cracked but has a carpet cover on top... anything electrical is in not so good shape...
The speedo - cable is unplugged in the cab hanging under the dash, cable is unplugged at trans Temp gauge does not work... I bought a triple gauge set and installed the water temp sender where the factory was on the driver side head - works great No dash lights - fuse is good - hooked new gauges to fuse as well and no lights for gauges... maybe headlight switch? No turn signals... I can get one side to flash with hazard lights - but I don't even see the 4-way flasher in the fuse box wtf... parking lights work fine, high beam/low beam No radio - doesn't even come on... looks like factory cassette No interior lights, hoping it's bulbs I have a mechanical oil gauge to hook up but I want to get copper tubing from advance first and I'm not sure where to install it
2002 Mustang GT Convertible (Mineral Grey) 2003 Mustang GT Convertible (Triple Black - wife D/D) 2013 Ford F550 XLT (Tow Truck - my D/D) 2006 Kawasaki Vulcan 750 1984 C10 Custom Deluxe |
Re: No Instrument Lights, Turn Signals, Radio
Did you check the ground on the dash to the cab near the headlights switch. Or did you yank on the wires @ the bulk head on the firewall break a wire knock on e loose, when working on the motor in stall.
Did they work before. If they did you may want to check your fuse box for power on lines not working.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bedWas a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
Yep, the headlight switch and dash need to be grounded. For electrical stuff you'll need a voltmeter.
| Bookmarks |
