![]() Join Date: Oct 2012
did not think 18 wide tires would fit..they do
I went from 29/15/20 to 29/18/20 and there close..but they fit no problem
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9 |
meowMEOWmeowMEOW
Re: did not think 18 wide tires would fit..they do
18" wide rims? Thats gotta be a typo. That would be like a giant construction wheel.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
Post Whore
![]() ![]() Join Date: May 2015
don't know about rims but they defiantly make a tire that wide...uses 15-16" wide wheel..was gonna use these tires (different size) on mine until I read about their lack of traction.....pic loks good...
https://www.summitracing.com/parts/m...MobileSwitchNo |
rims are 15 wide, tires are 18.. drives fine don't even know there back there...
Well, we need more photos than that!
Did you tub it out to get that size tire? If so, how much did you widen the tubs?
You will once you encounter any puddle of water. Be careful during any rain showers as well.
